car cuts out with gas
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
it seems it happens more often in 4th and 5th gear but whenever i give it any gas, whether alot or little, the car seems to be cutting out quite frequently. i put in some injector cleaner, that didnt seem to help.
anyhting i can do to test the injectors? can i have it idle and watch the fuel flow from them with the air cleaner off?
also could it be a bad sparkplug not sparking?
please help
please help
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Transmission: 4 Spd Auto
Nah if you changed it only 5 months ago im pretty sure that wouldnt be the problem. What about checking out the ignition to make sure everythings firing properly?
Car: '02 Z06
Engine: L33 5.7
i popped off the cap and i sanded the tip of the rotor so it makes good contact again. - still no good
only thing left is spark plugs?
and if worst case.. fuel pump
but im starting to notice, maybe its only happening in 5th gear, and if that is so.. that would be bad tranny trouble huh?
maybe the fifth gear teeth are broke or something?
Car: '02 Z06
Engine: L33 5.7
*bump*
i replaced spark plugs today as well.. still no good
tomorrow im replacing the fuel filter, if that dont work, im taking it to the shop and im gonna have them replace the fuel pump cuz i dun feel like messing with it.
Car: '02 Z06
Engine: L33 5.7
k&n open air element, just recharged it today as well. that didnt help. but i do thanks for your response!
it feels like its cutting fuel flow at throttle. but only on the highway! if im cruising in city, i never notice, but when im cruising highway with little throttle, its horrible, even when i floor it, its bad, and even in high rpm fourth, its not as bad.
i think it just gets worse with acceleration.
help please?
help please?
Car: '02 Z06
Engine: L33 5.7
how would that cause quick cuts to the fuel flow?
02 sensor isnt too old either, about 3-4 months old
AkDrifted
Aug 17, 2015 07:45 PM
