fuel pump problem
Old Mar 26, 2004 | 07:49 PM
5literTPIterror's Avatar
Car: 91 camaro rs
Engine: 355, blowthru, 78mm turbo
Transmission: th350, art carr converter
Axle/Gears: stock 7.5, 3.23s, minispool
fuel pump problem
a buddy of mine is having problems with his fuel pump, on a 85 IROC with a tpi 305...he's put two new ac delco pumps in it, and still is getting hardly any pressure..(right at the pump...not up at the intake) hes tried diffrent ground wires etc. still no success, only thought would be not enough power current to pump, but has no volt meter to test it...any help would help out a lotttt, he needs this car for daily transportation...
Old Mar 26, 2004 | 07:58 PM
PhilM's Avatar
Car: Accepting applications...
you'll need to get one somewhere and check the voltage, and here's another thing: did he check to make sure the filter is not clogged, or there aren't any other restrictions? I know it sounds silly, but I've seen this misdiagnosed as a pump problem before...
Old Mar 26, 2004 | 11:54 PM
Vader's Avatar
Let's see...
AC/Delco TPI fuel pump - $105.00.
Time to install - All day.
Cheapo digital multimeter - $15.00.
Time to diagnose - Half an hour, tops.
For all your automotive needs, there's MasterCard.
For evertything else, there is a mass of gray matter between the ears.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
Grant2k
Jul 10, 2018 04:01 PM
Infested
May 22, 2018 11:56 PM
92camaroJoe
Aug 13, 2015 06:07 AM
