Regarding 1992 Air Induction Baffles.. REMOVE??
Old Feb 25, 2001 | 10:17 PM
Camaro92's Avatar
While surfing the net I came across a site that said these plastic hoods over the air box in the 3rd gen camaro only have 2 purposes.
1. QUIET the air rushing in
2. REDUCE HP so it didn't look to have close HP to that of their Corvette car.
Is this true?
What would happen if you removed them (held by screws I hear)? How much if ANY HP will be achieved? Any change in sound? (I have an open Fiberglass hood and can EASILY hear the air sucking through the cowl from inside the car when you floor it. Will removing them cause any damage or risk water/dirt into the engine?
1992 Camaro Z28 v8 350. Blue/silver racing stripes, ASCD Iroc Daytona Fiberglass hood. Flowmaster otherwise stock.
Webmaster:
http://www.camarosource.ca
www.camarosource.ca
"Your Full Camaro Resource Site" - ALL Years, All Models
Old Feb 26, 2001 | 08:43 AM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
I have a book that says you should take them out to benefit from more air. Mine will be getting removed when my K&Ns arrive shortly
Take them out.
Robert
1987 IROC-Z Auto (LB9)
Black/grey interior with the stance of a streetfighter
Mods
Custom exhaust. 4 Inch pipe from the headders all the way back to a single muffler at the rear. No Cat.
Future mods due in March:
K&Ns
RAM Air
Air foil
AFPR
Hoping to get a couple of tenths with that lot
Old Feb 26, 2001 | 08:51 AM
Dan91Z's Avatar
they don't raise hp much when removed.. on a stock engine you'd be lucky to see a 1/4 of a hp increase. The reason for them was to quiet the incoming air charge for drive by noise levels. I removed mine a while ago, and can't notice the sound difference they were made to get rid of.. but then i'm always driving my car so I don't know what it sounds like on a drive by.
My `91 Z28 Convertible
Old Feb 26, 2001 | 11:29 AM
Paul Riccioli Jr's Avatar
Car: 89 IROC-Z
Engine: 383
I believe that they are very effective in keeping water out. When I first got my K&N's I took mine out and after the first real rainstorm I pulled the filters and they were pretty wet (not their oil either). I put mine back in and I didn't notice a real difference anyway.
Riccioli Performance Motorworks
--RPM Racing--
-Currently building first ever engine. 383 with Super Ram plenum and runners, Edelbrock lower intake, Bosch 24# injectors, either AFR or Trick Flow heads, MSD ignition.
-Will be installing Baer Brakes
-Will be installing full Spohn suspension in rear
-Art Carr 700R4 trans??
***** Flyby: (n) When you let off the throttle after beating a ***** Racer by a few car lengths and he then blows by you in an attempt to convince you he really won the race.
Old Feb 26, 2001 | 04:11 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
And some of us have gone even further and hacksawed the bottom of the air boxes out to completely elimate any hope that that part was ever going to be a restriction. I doubt it's worth any HP on a stock car, but do all the free mods you can, after all, they are free.
Just remove them. Unless you drive into a lake (in which case you'd have worse problems to worry about, eh?) water is not going to make it into the engine through there. In fact, i don't see how they could possibly get wet at all (unless lake driving), directly below the airboxes is ducting that goes from the fog light holes to the radiator, so even if somehow water splsed up, they couldn't get wet through the fog light holes, and water couldn't splash from the ground up to them because the aforementioned ducts are in the way.
...ed
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
1992CamaroGirl
Dec 25, 2017 08:45 PM
3rdgenparts
Aug 8, 2015 07:09 PM
