Spark Crossfire?
Old Mar 27, 2004 | 07:16 PM
L98 Z28's Avatar
Car: '92 Z28
Spark Crossfire?
I'm trying to figure out an ignition problem. I have a balancer cover that has marks every 90 degrees. If I hook up my timing light up to my #5 cylinder, I usually see one of the 90 marks, but sometimes it will show the timing marks near TDC. I assume this is from the cyl 6 spark. I have fairly new SpiroPro Taylor wires, which I've read mixed reviews on, so I've put some old Accel wires on cyl. 3, 5 and 6 to see if it just the wires causing the crossfire. The problem was still there with the Accel's, so it doesn't seem to be the wires. The distributor cap and rotor are fairly new, so this wouldn't be due to any type of old cap problems.
Can a new cap cause crossfire? The plugs are new, but I can swap #6 out if a bad plug with high of resistance might cause crossfire.
Anyone have a possible explanation?
Thanks.
Joe
http://home.cfl.rr.com/shuhy/chevy.htm
Old Mar 27, 2004 | 09:55 PM
L98 Z28's Avatar
Car: '92 Z28
I swapped the #4 and #6 plugs and the spark problem is still there. I guess I'll put on an old cap and rotor next. Good thing I keep old parts around.
Old Mar 27, 2004 | 10:08 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
I've run those same wires for the last 15 years or so on everything I have; cars, boats, etc. They work fine. They're not the problem, at least not if they're properly installed, and routed correctly: not running all together their whole length, which would be tough for #5 & #6 anyway.
I'd suspect that your rotor's contact is off to one side. If the cap isn't perfectly lined up and seated, it will be slightly cocked, and the rotor contact tip will hit it and get knocked off into the ozone.
Bubbajones_ya
Oct 25, 2015 08:01 PM
NZKnight
Oct 15, 2015 02:47 PM
HoosierinWA
Oct 7, 2015 10:15 AM
meeklay812
Oct 1, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
