CODE 44 update. please help
i changed my o2 sensor today. and shure enough the bastard light still comes on when idling for a little while
ive changed plugs, wires, cap, rotor,coil,02 sensor .. whats my next move?
CODE 44 : lean exhaust
AIM: grvkill
ICQ: 29298583
AIM: grvkill
ICQ: 29298583
Disconnect the battery and let the car sit for between 1/2 to 1 hour and reconnect the battery. This will reset the computer. I had to do the same thing when I changed my o2 sensor in my other camaro.
Car: 91 camaro
Engine: 383
Check the purple wire from the O2 sensor to the computer, make sure it's not shorting out to ground. Is it possible that your car really is running lean? If it is running lean, and the computer can't compensate for it, it would throw a code. This could be caused by a vacuum leak, plugged injectors, or a problem with the MAF. Also, it could be your cumputer.
Ok, since you have an 84 305, disregard anything about injectors or a MAF since it would be carbureted (if stock). If it's still lean (though i assume you have fixed it) you would have to tap into the mixture control solenoid and richen it by 1/4 turn of the screw. viola! problem solved.
--Steve S--
1984 Trans Am 305 LG4, 5 speed
Daily Driver, Flowmaster 80 Series
NOW FEATURING: Holley 600 cfm & vacuum advance
--Steve S--
Keep in mind that when you reset the computer, you need to drive like grandma for about 20 mins, so the computer can relearn stuff. If you just go *****-out, you will experance alot of gas consumption for nothing.
Rob
'86 TA 305 TPI
Gutted MAF
Ported Plenum
TB Bypass
Rob
'86 TA 305 TPI
Gutted MAF
Ported Plenum
TB Bypass
