Throttlebody linkage for 86 TPI
Old Feb 27, 2001 | 09:22 AM
Kyle F's Avatar
OK for all the infor you may need check my sig. Ok here is my question/problem. I bought a 58MM BBK Throttlebody for my 355 TPI this past summer. Well the linkage was a little different on the new on compared to my old one. What I am thinkin is that it has the styl for the later model cars. Mine has those pin on the spring mechanism that that you slide the throttle cable over then clip it on. Well the BBK didn't have that for the throttle but did for the AT kick down. At any rate being a Mechanical engineer and seeing how I bought the damn thing in Columbus (Jegs) and being 2 hours away from there I decided to rig it in with a screw and a nut to form a pin and use the bolt as a clip and to apply pressure to stay in place. Works fine for slammin the gas to WOT, but it doesn't provide smooth actuation in other driving conditions and the spring wont always bring it to a complete close.
Ok my idea is that I might just need to install a throttle cable from say a 91 TPI. Will this fix the problem or am I stuck with it?
86 Trans Am 355 TPI Rebuilt 700R4 with Corvette servo, modified valve body, and a B&M Torque Converter (2000 rpm stall w/ lock up), 87 350 block bored .30 with new crank. Reworked 305 heads with 3-angle valve job. Added in the rebuild was an SLP TPI cam, BBK 58mm Throttle Body,MSD 6A, Hypertech Power Coil, 1.5 Crane roller tipped rocker arms, SLP Intake Runners and Port matching in upper intake including fully ported plenum, TPIS adjustable fuel pressure regulator @ 46psi, Hooker shorty style headers w/ Thermotech heat wrapping, Custom 3” exhaust with Flowmaster muffler and chrome quad tips, Hypertech Thermomaster Computer chip, K&N open element cone filter on modified MAF per TPIS specs, MSD Wires, removal of A/C hardware and added a 1LE firewall cover installed. Also there has been a PST front suspension kit with Hotchkis strut tower brace added. Soon to have Intrax lowering springs.
http://geocities.com/SunsetStrip/Garage/9548/kyle.html
Kills:
95 Talon TSI, 96 Probe GT, 91 T/A L98, 89 RS, 86 Mustang GT, 88 Mustang LX 5.0, 92 Thunderbird V8. couple or ricers that I think were Civics or Preludes not sure what year, 95 Celica GT-S, 94 Chevy 1/4 ton 350, one of those NASCAR F150's
The Third Gen Will Never be Forgotten
Old Feb 27, 2001 | 04:54 PM
Kyle F's Avatar
Anyone?
Ghettobird52
Apr 21, 2020 08:44 PM
stalkier
Dec 6, 2015 11:25 PM
spaigo
Aug 21, 2015 07:46 PM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
