anyone useing rtv sealent around water jackets on head gasket?
Old Feb 27, 2001 | 02:47 PM
bad camaro RS's Avatar
i had a head gasket start leaking by one of the water jackets im getting ready to put new gaskets on should i use rtv or no?
1992 camaro RS
195cc AFR heads with compition port work milled to 58cc "10.9 to 1 compression"
373 10 bolt rearend
ssm sfc's
87 350 TPI
bored 30 over
compucam 2032 with 1.65 full roller rockers
497-510 LIFT 214-220 duration
msd6AL
1 5/8 headman headers
2 `1/2 flowmaster exuast
k&n filters gutter air box gutted maf"no fins no screens"
3 pc under drive pulleys
no emissions no egr etc
custom ED Wright chip
eddelbroc intake base and runners ported plenum
accel 8.8mm wires
B&M mega shifter
gutted maf/airbox
hotchkis lower control arms
3" exhuast cutout
homemade cold air intake
2000 tci stall
700R4 with B&M shift kit edelbrock water pump
new best ET 13.5 @104.66
no times with new afr heads hoping for 12's on motor
Nos to be installed soon
Old Feb 27, 2001 | 05:29 PM
ede's Avatar
ede
as a rule you don't need sealer between two machined surfaces. i believe i break most of these same rules. when i do a head gasket i use k&w copper sealer in a spray can and have never had a leak. i think i'd be checking for warpage before i put it back together. if you find nothing i might try soem permatex rtv ultracopper on the block and head where it leaked, but very little.
ICON Motorsports
1st & 3rd
1992 Trans Am
May 10, 2023 07:19 PM
NinjaNife
Aug 23, 2015 11:49 AM
lakeffect2
Aug 23, 2015 08:44 AM
89-S-dime
Aug 12, 2015 11:57 AM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
