Engine ground
Old Feb 27, 2001 | 03:44 AM
Omar's Avatar
Engine ground
Is there any logic AGAINST upgrading the braided strap at the firewall to something like 4 gauge wire?
1989 IROC-Z 5.7L
Old Feb 27, 2001 | 09:00 AM
Demon Z28's Avatar
Car: 2001 Camaro SS
Engine: Almighty LS1
is there really any point?
Old Feb 27, 2001 | 03:52 PM
The ODB's Avatar
NO,
the grounding is the most important part of your electrical system. A better engine to chassis ground will improve the performance of your alternator, starter, and ignition system.
If you have your battery relocated to the rear with a battery-chassis ground, the engine-to-chassis ground is even more important.
high quality copper & many fine strands make the best cables. The premade cables from autozone are low grade with only a few large strands inside.
Old Feb 27, 2001 | 08:52 PM
JoelOl75's Avatar
Car: 88 Firebird WS6
Welding cable works good. The large strands can fatigue over time from vibration over a short span.
Good places are to ground the heads to the frame and firewall and I also grounded the starter casing to the frame. Ground probs are the hardest to deal with and putting the battery in the trunk can bring these problems lurkin'
'88 Camaro RS 2.8L
'88 Formula 350 (Too many mods to list...)
[This message has been edited by JoelOl75 (edited February 27, 2001).]
BRoss99
Aug 10, 2025 05:08 PM
E Rod
Aug 28, 2015 05:17 AM
Jae992
Aug 27, 2015 09:07 AM
justin57
Aug 20, 2015 07:05 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
