NEED HELP ASAP!!!!!!
Old Feb 27, 2001 | 07:39 AM
menace88SC's Avatar
Car: 87 Trans Am
Engine: 5 point slow LG4
hey guys,
a friend of mine is having some trouble with her 92RS with the 5.0L and we need to get it figured out quick.
the problem is that it keeps shutting off. it will run for awhile, but then the check engine light will flicker a few times and then it cuts off. after sitting for about a minute or so, it will fire back up , but during that minute it wont crank or anything. any help or you guys can offer would be greatly appreciated.
and does anyone remember how to scan the computer with a paper clip???
peace,
menace
Lady Justice wears a blindfold & carries a sword. And when blind people take up fencing, the innocent are bound to get hurt!
Old Feb 27, 2001 | 08:03 AM
Box of Rocks's Avatar
88SC,
You have a loose electrical connection somewhere. Starting from the battery positive and negative connections, follow the power and ground back up toward the ignition switch.
I believe the 92's have multiple relays, not to mention VATS to diagnose, so someone with another '92 can be of more help than I can - and a BSEE wouldn't hurt here either.....and I'm a "cold wire" guy.
Uh, coils can become overheated and fail too......yup, ask some of the smarter guys, not me.
I'm just a Box of Rocks.
BOR
Old Feb 27, 2001 | 08:10 AM
burnoutrpm's Avatar
check ypur battery wires thats all it is. justa really bad connection! ok in that min. you said try to keep turning the key forward, i garantee that it will eventually click and start if its electrical problems sound like the ground isn't grounded.
1989 firebird formula
Mods: converted from T.B.I. to a carburator 305 to a 350. Flowmater exhaust,hedman shortie hedders,202 160 (882) heads,.447/.447 lift 222@.050 duration speed pro 327/350hp cam 350 .40 over (356) edlebrock performer rpm intake and a 600 edlebrock manual choke (1405) Proform H.O. distributor slightly revised 700r-4
Future mods comp extreme energy roller cam, world products sportsman 2 heads, msd 6al ignition, billet distributor, blaster 2 coil and a 406 engine is in the works soon!!!!
Old Feb 27, 2001 | 01:37 PM
ViciousZ's Avatar
Car: 91 camaro
Engine: 383
Yeah, it sounds like an intermittent wiring problem, or something to do with the VATS, maybe? One quick question to help with the diagnosis: when the car dies and won't start, do you have power at that time? I mean, do the headlights, radio, etc. work? Knowing what does and doesn't work will help you figure out where to look for the problem.
Old Feb 27, 2001 | 10:13 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
It shouldn't be VAT's, I can take my key out of the car when it's running, with no problems.
If no codes are stored and if the tach sorta jumps in time with the SE light flashing, I'd be thinking ignition module or PU coil.
Others bring up a good point...check all the little grounds on the rear of the heads, make sure they're not loose, and have good contact.
Old Feb 28, 2001 | 07:06 AM
menace88SC's Avatar
Car: 87 Trans Am
thanks all the help thus far guys; it is very appreciated!!
peace
menace
92GTA
Apr 9, 2016 07:39 AM
86White_T/A305
Mar 6, 2016 01:48 PM
Brother Al
Oct 14, 2015 06:39 AM
92projectcamaro
Sep 24, 2015 08:09 AM
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
