Fuel Pump Push Rod?
Old Feb 27, 2001 | 09:19 PM
gruveb's Avatar
Car: 1989 IROC-1
Fuel Pump Push Rod?
I have an 84 Z28, L69. I'm in the process of mod'in the engine this week. I've pulled the mechanical fuel pump off, but I don't see a push rod. I do see a broad piece of metal that points at about 7 o'clock or so if you were looking at the timing chain cover as a clock.
Does this move up and down to actuate my fuel pump?
Just checking.
Thanks,
Old Feb 27, 2001 | 09:26 PM
Vader's Avatar
That would be the push rod...
Later,
Vader
"No matter how hard you try you can't stop us now..."
Adobe Acrobat Reader 4.0
Old Feb 27, 2001 | 09:30 PM
gruveb's Avatar
Car: 1989 IROC-1
I can't remove it though?
Old Feb 27, 2001 | 09:41 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
Yes, remove the lower bolts in the fuel pump block off plate. This plate will come off and the pushrod will fall out.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
R.I.P. #3
My favorite quote about D.E. "He can see air"
Old Feb 28, 2001 | 07:50 AM
gruveb's Avatar
Car: 1989 IROC-1
I see the two bolts now.....I was dead tired last night.
Thanks again.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
Reborn756
Sep 4, 2015 03:42 AM
92camaroJoe
Aug 13, 2015 06:07 AM
