oil filter adapter need seal?
Old Feb 27, 2001 | 12:34 AM
AustinT's Avatar
I am swapping everthing from my 305 to my zz430. I pulled the spin on oil filter adapter off the 305 and it did not have a seal? Do I need a seal?
Old Feb 27, 2001 | 11:37 AM
Paul Riccioli Jr's Avatar
Car: 89 IROC-Z
Engine: 383
How does that oil filter adapter fit onto the block anyway? I thought there were little bolts that went through it, but when I ordered them from Chevy I got some kind of studs instead?
Riccioli Performance Motorworks
--RPM Racing--
-Currently building first ever engine. 383 with Super Ram plenum and runners, Edelbrock lower intake, Bosch 24# injectors, either AFR 190 heads, MSD ignition.
-Will be installing Baer Brakes
-Will be installing full Spohn suspension in rear
-Art Carr 700R4 trans??
***** Flyby: (n) When you let off the throttle after beating a ***** Racer by a few car lengths and he then blows by you in an attempt to convince you he really won the race.
Old Feb 27, 2001 | 07:18 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
2 bolts hold it on, no gasket.
If you don't have the bolts, you must use allens or the original type bolts. The socket head is smaller than normal to clear the oil filter.
The ones with an oil cooler have a paper gasket and an O-ring beteen the block and the adapter.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
R.I.P. #3
My favorite quote about D.E. "He can see air"
[This message has been edited by Engineboy (edited February 27, 2001).]
Old Feb 28, 2001 | 01:45 PM
Mike89GTA's Avatar
Yea, I replaced the o-ring on my GTA, it was leaking after I took it off for a few months to change the engine. That o-ring is impossible to find, first time I had to special order something from the dealer (I was in a huge rush to try out my new engine and wanted to find it in stock..)
Old Feb 28, 2001 | 02:12 PM
Car: 89 IROC-Z
Engine: 383
Anyone have the size on those bolts? Is the head smaller than normal? Why the hell did the dealer sell me studs for it?
--RPM Racing--
Old Feb 28, 2001 | 03:33 PM
Scott C's Avatar
Paul,
It appears that your dealer gave you the wrong stuff?
I have a concern on this too. I recently swapped the adapter from my 305 to a brand new GM 350. There is a black "pressure valve" thingy on the adapter. Does that thingy have to face a certain way? Meaning that the adapter can go on "this way" or "that way"...is either way the right way or does it even matter? Thanks!
Old Feb 28, 2001 | 07:35 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
It doesn't matter which way you face the by pass valve. I usually look at the engine where it mounts, you will see where it was.
Yes, the heads of the bolts are smaller than normal. Use allens or get the right bolts from GM.
I'll look tonight at the size.
1999 NBM Trans Am
1981 corvette
1995 Kawi ZX6R
R.I.P. #3
1992 Trans Am
May 10, 2023 07:19 PM
maroe624
Apr 16, 2017 08:29 AM
Navy8125
Aug 21, 2015 09:32 AM
355sbcTPI
Aug 19, 2015 04:38 PM
