Removing Motor from Tranny
Old Mar 1, 2001 | 01:45 PM
Brian Felts's Avatar
Car: 89 RS 355/ 89 IROC Convert
Engine: Hot Cam 355/TPI 305
Transmission: All 700r4's
I am ready to pull this motor and I can not get the Short block to seperate from the Tranny......Any Ideas????
Brian
Old Mar 1, 2001 | 01:49 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
All the bolts out?
What kind of motor and trans? We can tell you how many bolts you should have to remove.
ICON Motorsports
Old Mar 1, 2001 | 01:58 PM
Well I got out
3 converter bolts
2 bell housing by oil filter
2 by the starter
2 on top
I can lift the motor and the tranny pulls up a little but it seems stuck
Brian
Old Mar 1, 2001 | 03:11 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
That's the correct number of bolts...
Sometimes the dowel pins between the motor and trans get stuck. Try using a screwdriver or something to pry them apart. Don't forget to have the trans supported by a jack or whatever, it will fall out if it's not.
ICON Motorsports
mhatfield 14
Aug 15, 2015 10:47 AM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
3rdgenparts
Aug 8, 2015 07:09 PM
drathaar907
Aug 6, 2015 04:20 PM
