Powerhouse 383 stroker kit?
Old Apr 7, 2004 | 11:29 PM
  #51
pre's Avatar
pre
Car: 87 Firebird
Engine: 305 LG4
Transmission: THM700R4
Just screw the heads and cam until you get more money. Spend what you have now on headers y pipe, cat-back, and cowl hood or some other air induction setup than that.
If you do the cam and heads without the exhaust you will have a large restriction that wiill make you see little gains.
From what I have read on this site the main restriction are exhaust mainfolds, exhaust itself, cam, air induction, and gears.
Old Apr 8, 2004 | 12:11 PM
  #52
Trans_AM_88's Avatar
Car: 1986/88 Frankenstein Trans Am
Engine: carbed L98
well i have a hooker catback right now and im about to get hedman shorties and a custom y-pipe and no cat. ill get a 2 or 3 inch tall 14" k&n air cleaner (and the hood i guess since it wont fit)
i think im going to get the gears first though, they are more expensive
Old Apr 10, 2004 | 03:38 PM
  #53
Engine: carbed L98
what 14" air cleaner will clear a stock hood? i have an L98 w/ edelbrock performer and a holley carb
Old Apr 22, 2004 | 11:17 PM
  #54
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
(ME Leigh- you said I have to admit that $359 bucks for a set of heads is a pretty good deal. That is if your not looking for a performance increase, just a new replacement head.)
ME Leigh just because you think that upgrading valve springs is the same as what aerohead does to there products doesnt make it the truth man ..obviously you havent built many engines in the past or something..but bigger valves always helps in performance over a set of stock valves anyday ...lol....but im not gonna argue with the college know it all.....ive built plenty of engines in my time so far and have always gained performance from a set of 2.02 1.60 valves .....i dont know what your thinking?????
anyway dont listen to half of what you read on here some of the guys really know there stuff and the others are just talkin out there a**...and they only want you to listen to there opinoin and all i gotta say about that is build what you wanna build dont build and buy what others "say" is the best cause about anything you buy out there is gonna be a decent part
Old Jan 20, 2012 | 06:41 PM
  #55
Guest
Guest
Posts: n/a
Re: Powerhouse 383 stroker kit?
Originally Posted by Trans_AM_88
has anyone ever heard of Powerhouse? they make engine kits among other things. here is their site: http://www.enginekits.com/catalog.pdf
they have a 383 stroker kit (2 pc seal) for $669 that i was looking at.
it includes:
Powerhouse flat top stroker pistons
Pro Street style rings
Pro Street cr1 5.7 connecting rods
main and rod bearings
full gasket set
new balancer
new flexplate
*balanced*
what do you guys think? is this kit any good and does this kit work with a stock L98 (carb'd)?
the only problem is that they are not internaly balanced so the tend to waller out the guide pin on the crank shaft because the 400 harmonic balancers are so big and heavy, other than that they sale good quality stuff that can take a beating, my suggestion is buy the kit, find a machinist that has the equipment and spend the extra $200 or so to get the crank internaly balanced, your engine will rap up faster and be able to turn alot more rpms. plus it will take alot of strane off of the rotating parts...
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
sleprock
Oct 1, 2015 09:39 AM
buckshot63
Sep 10, 2015 09:15 AM
!CamaroDave
Members Camaros
Sep 5, 2015 10:39 AM
