Water neck sensors
Old Mar 1, 2001 | 08:13 PM
Alan84TA's Avatar
Water neck sensors
What are the two sensors in the water neck? I had the engine rebuilt and they did not give me my old intake back. I think one is the coolent temp sensor for the ECM. What is the one with the two vacum? lines running to it? Also I got a new coolent temp sensor but it doesn't fit the hole in the new water neck even though it looks just like the original.
Old Mar 1, 2001 | 08:55 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
You're right, the one is the CTS for the ECM. The mystery one is the temp vacuum switch for the EGR. IIRC both of them should be 3/8" pipe which is a little bit of an unusual size.
ICON Motorsports
Old Mar 1, 2001 | 09:25 PM
Alan84TA's Avatar
Hm... If they are both the same size I got the wrong water neck then. one hole is bigger.. I thought that might be the case..
Hotrodboba400
Dec 10, 2019 07:07 PM
92firebirdguy
Sep 1, 2016 07:53 AM
customblackbird
Oct 1, 2015 04:30 PM
m00n420
Sep 11, 2015 02:39 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
