Fuel pump keeps running, Why?
Old Feb 26, 2001 | 08:09 PM
FIRECHICKEN's Avatar
Car: '89 Formula 350
Engine: 5.7L L98 TPI
Transmission: 700-R4 Automatic
Axle/Gears: 7.5 disc posi 3.23
Why does my Fuel pump keep running after I shut the car off? It runs until the oil pressure drops to near zero. Is the problem in the oil sysem or it's sensors. Or is the problem in the Fuel Systems or it's sensors??
Electrical Gremlins???
89 TRANSORMULA WS6 5.7
Dark Purple Hardtop!
Ram Air II Hood
Z28 Hi-Rise Spoiler
HYPERTECH THERMO MASTER
10-BOLT POSI, 3.23 GEARS
MODIFIED TRANSMISSION
K&N FILTER CHARGER
MODIFIED MASS AIR SENSOR
PORTED & POLISHED INTAKE
ACCEL COIL & 8.8 WIRES
EMISSIONS DELETE
DYNOMAX EXHAUST W\ TIPS
CUSTOM SOUND SYSTEM
BEST TIME 14.32 @98.3 mph
Power buldge hood
^^ FOR SALE ^^
Old Feb 26, 2001 | 08:57 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
Sounds like the relay is getting stuck causing the sensor on the oil pressure sending unit to finally shut it off.
Old Feb 26, 2001 | 09:12 PM
Vader's Avatar
FC,
Inspect the fuel pump circuit. This phenomenon is completely normal, and means that the auxilliary oil pressure switch is working correctly.
Mine does this as well, and has since it was new. As long as there is 7 PSIG of oil pressure in the main gallery, the switch should be closed, causing the pump to operate.
Later,
Vader
"No matter how hard you try you can't stop us now..."
Adobe Acrobat Reader 4.0
Old Feb 28, 2001 | 09:28 PM
I believe that the relay is not at fault. I replaced the relay thinking this same problem. It still did it.
I also don't think that the car did this ever since I got it. But it has been getting worse lately. Shouldn't the FP cut off with the ignition switch. I was under the impression that the oil pressure cut off was only for the event off an oil pressure loss while the engine was in operation.
Old Mar 1, 2001 | 10:10 PM
Vader's Avatar
FC,
There's the circuit - you decide if it's normal or not.
Later,
Vader
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
theshackle
Mar 5, 2017 06:37 PM
justin57
Aug 20, 2015 07:05 PM
92camaroJoe
Aug 13, 2015 06:07 AM
