Check enigine light?
Old Mar 1, 2001 | 09:32 PM
toady1's Avatar
I have an '88 model throttle body 305 Firebird. It starts fine when it's cold but Once it's hot it's hard to start. Once I finally get it started again And I accelerate it cuts out like it is not getting enough fuel. I've put on a new fuel filter, Fuel relay, and oxygen sensor and nothing helped. Trouble code 42 shows up So I replaced the electronic spark control. What could be causing this?
Old Mar 1, 2001 | 10:31 PM
Vader's Avatar
Toady,
You need to dig a little deeper into the ignition system. Hot restarting ignition problems can be caused by a weak ignition coil, failing HEI amplifier module, failing pickup coil, faulty wiring, a cracked reluctor, incorrect timing, or failing filter capacitor in the coil primary circuit.
Other causes of hard hot restart can be flooding, improperly adjusted TPS, failing coolant sensor, and excessively low compression.
Start testing.
Later,
Vader
"No matter how hard you try you can't stop us now..."
Adobe Acrobat Reader 4.0
Old Mar 1, 2001 | 10:54 PM
bullfrawg's Avatar
what are you calling the electronic spark control? Because that is a series of sensors and modules. But i think you problem might be the ignition module, or a cracked distributor cap
1985 TransAm BLK/GLD Stock
1985 TransAm BLK/BLK
305HO (soon as it is put in) 5-speed, 3.27 posi, WS6, power everthing.
http://www.geocities.com/bullfrawgs
Old Mar 1, 2001 | 11:06 PM
bullfrawg's Avatar
i just got out my book and here is exactly what it says the problems may be. I would check these first. "choke sticking in the closed position. Air filter clogged. engine flooded. fuel not reaching the injector system. defective fuel or emissions systems control components
It could be any of these things that we have said. I would start with these first.
[This message has been edited by bullfrawg (edited March 01, 2001).]
chazman
Aug 28, 2018 03:25 PM
Wade787b
Sep 29, 2015 01:15 PM
litemupp
Southern California Area
Aug 23, 2015 10:09 PM
chazman
Aug 22, 2015 02:01 PM
