exhaust needed for 400 horses
Old Mar 1, 2001 | 08:39 AM
Brandog87GTA's Avatar
I have hedman headers with a custom 2 1/2 inch Y pipe on each side which connect to a 3? inch main pipe that leads to my two chamber flowmaster which exits with two 2 1/2inch pipes. Is this an adequate exhaust for my application? Or can I do something better?
Bright red 87 GTA with I have stock 3.27 gears,stock converter,B&M shift kit, TRW forged 9.75:1 pistons,comp cams pushrods, edelbrock valvesprings, 462 camel hump heads with 2.02in/1.60ex redrilled for angled plugs, 3 angle valve job, ported and polished, performer RPM intake, mallory fp regulator, edelbrock 750 CFM carb, hei ignition(new) with 10,000 volt coil,No cat, flowmaster 2 chamber mufflers, hedman full length headers, edelbrock cam with 488/501
Old Mar 1, 2001 | 12:50 PM
Polecat's Avatar
Sounds about dead on. With that combo you have, you have upgraded exaclty how I would have. Any more won't really gain you anything. It actaully might start hurting HP and TQ.
Later!
350 4 bolt main, Speed-O-Motive 383 stroker kit, re-sized rods ground for clearance,TRW Forged pistons,10.7:1 compression,HPC Coated RPM intake, Speed Demon 750 cfm carb,World Products Sportsman II heads,2.02/1.60 valves, Comp Cam 1.6 roller rockers, Comp Xtreme 284 cam,240/246@.050 with .540 lift,Crane pushrods,ATI damper,Proform HEI and MSD6A box,HPC coated 1 5/8 headers, 2.5" exhaust with 40 series mufflers,TH350 with B&M 3000 stall, Powertrax NoSlip Locker, 4.11 gears.
Old Mar 2, 2001 | 10:08 AM
FastBroker's Avatar
Gonna be close, man, especially if you have only 1-5/8" tube headers. Really need 1-3/4" headers, especially with 2-into-1 exhaust!!!
[This message has been edited by FastBroker (edited March 02, 2001).]
IROCZ1989
Jan 24, 2016 03:55 PM
camaro71633
Sep 1, 2015 10:24 AM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
