How do Vortec 305 heads compare to 416's-601's?
Old Apr 4, 2004 | 02:47 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Just courious if anyone has gone into any detail comparing 416's ect to the vortec 305 heads? I cant find too much comparison data its mostly vortec 350 castings.
Thanks.
Old Apr 4, 2004 | 02:58 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Never actually flowed a set but they should be lil diamonds in the rough. The ports are simular to 350 L-31 vortec heads. The small combustion chambers are shaped more like a 305 TPI head (081) castings. they a have 305 sized 1.84 x1.50" valves.
Sort of a mixture of TPI and L-31 vortec features.
In stock form they probabily flow simular to a 305 TPI head (081) or 305HO (416).
People are bound to turn their nose up at them so you should be able to score a set cheap.
I'd say if you come across a set for cheap and don't mind putting the porting work into them with larger valves you can get good performance out of them
for low $$$.
I think the Stock vortec EFI intake manifold has good performance potential too with mods.
the 305 vortec casting # ends in 059 or 520
Old Apr 4, 2004 | 05:35 PM
robertg's Avatar
Car: 2000 astro
Engine: 4.3
Transmission: A4
Axle/Gears: 7.5 with 3.42 gears
i've read that 305 vortec heads actually have a bit of a swirl-port to them :shrug:
Old Apr 5, 2004 | 01:33 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Well actually were considering using these 98 305 Vortec heads Ive had laying around for 2 years on an 89 TBI camaro with ?X? vortec manifold and an adaptor plate just to see if it would wake up an LO3.
Jake_92RS
Jan 28, 2020 10:37 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
Fast355
Dec 2, 2016 06:33 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
