Cam size w/ 1.6 rockers?. . and some other questions about aluminum heads.
Old Apr 5, 2004 | 01:38 PM
Gunny Highway's Avatar
Car: 91 RS
Engine: 350 TBI
With 1.5's the cam's specs are:
Dur @ .050: 204/214
Lift: .429/.452
L/C: 116
Also, will my compression change going to Trick Flow Alum heads as long as I stay with 64cc's? (350 TBI by the way)
And what is the benefit of CNC chambers as opposed to not? Worth the money?
Old Apr 5, 2004 | 01:53 PM
ede's Avatar
ede
.458/.482 basically nothing else will change, this will lead to a big fight and discussion about cam specs with any luck. cnc machine ports are good because they should all be exactily the same with no varaition for casting or hand grinding. compression shouldn't change as long as volumn doesn't
Linson
Oct 24, 2025 02:00 PM
Pac J
May 17, 2020 10:44 AM
