changing freeze plugs with motor in car
Old Apr 4, 2004 | 07:25 PM
llvll4l2c91350's Avatar
what's involved in doing this? what special tools do i need? is it possible to do it with the motor in the car?
i have a running 350 TPI motor in another car but some of the freeze plugs on each side of the block are leaking. i dunno if i'll ever get to rebuild this motor but i'd like to at least fix the freeze plug problem without having to pull the whole thing outta the car.
TIA
Old Apr 4, 2004 | 09:07 PM
Vader's Avatar
Core plugs on the sides of the block can usually be replaced with the engine installed, but you'll have to remove some parts to gain access to some. The starter, exhausts, steering pump, A.I.R. pump, and other accessories may have to be removed depending on which plugs you're trying to replace. No special tools should be necessary.
Old Apr 4, 2004 | 11:23 PM
doesnt sound too bad. thanks. so can i just walk into any parts store and get freeze plugs for a SBC? (never bought 'em before).
Old Apr 5, 2004 | 01:45 AM
fast89RS's Avatar
Car: 1989 Camaro RS
Engine: Vortec 350
Transmission: Built 700R4
Yep.
Old Apr 5, 2004 | 05:46 AM
ede's Avatar
ede
don't forget to use sealer on the lip of the plug.
Old Apr 5, 2004 | 08:40 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Are you sure the 2 on the back of the block, inside the bell housing, aren't leaking too?
Reason I'm asking is, you'll go through probably more labor changing those side ones out in the chassis than pulling the motor; and if those are rusted from the inside, the others can't possibly be far behind. May even be worse, who knows. You might go through all that work, and 2 days later, come out to your car in the morning to see coolant dripping out of the bell housing.
Bottom line is, if I was you and I had 2 or more known rotted out freeze plugs, I'd change all 8 of them; and I'd put brass ones in this time instead of steel.
Old Apr 5, 2004 | 01:59 PM
i dunno about the back ones. like you said they may not be far behind if they're not already leaking. the thing is i'd like to change 'em all but would rather not have to put the motor on a stand. if i do that i might as well rebuild it but dont wanna mess with that yet. it's got 156K miles but runs perfectly smooth with good compression. i plan on changing all the gaskets, seals, run synthetic oil in it and drive it. i'm guessing i can just pull the motor out with a picker and change 'em right there real quick then drop it back in the car? or should i put it on the stand in case the job takes longer than expected?
1992 Trans Am
May 10, 2023 07:19 PM
slade5612
Aug 11, 2015 07:19 PM
1nastygta
Aug 8, 2015 07:38 PM
mustangman65_79
Aug 8, 2015 01:18 AM
92projectcamaro
Aug 6, 2015 01:20 PM
