egr and vortec heads
Old Apr 4, 2004 | 04:25 PM
walterrao's Avatar
Car: 91 RS
Engine: vortec 355 hsr
Transmission: wct5
Axle/Gears: bg3.27
i heard that there can be problems adapting vortec heads for egr, is this true, and if so what is the problem, or how do you get around this problem.
-walter
Old Apr 4, 2004 | 04:49 PM
vjo90RS8's Avatar
Car: 2002 Z28
if u know to retain EGR for emissions use the vortec TBI intake. The vortec heads use an external egr system which draws exhaust gases from the AIR tubes of one of your exhaust manifold/headers. So one set of AIR tubes will be used for egr purposes and one will be used for air injection via the smog pump/diverter valve. You will have to run a hose from your AIR tubes to the tapped EGR thread in the front of the intake manifold.
When the egr valve opens, it will suck exhaust from the headers.
Run a search, there are a few pics of this setup.
Old Apr 7, 2004 | 11:00 AM
walterrao's Avatar
Car: 91 RS
Transmission: wct5
Axle/Gears: bg3.27
which manifold are you talking about, the gmpp one or does anyone eles make one. and is there a way i could adapt the non vortec edelbrock manifold to fit vortec.
Old Apr 7, 2004 | 11:17 AM
FlamedROC's Avatar
Car: 1989 IROC-Z
theres really no way to take a non vortec intake and make it work...u could but thats alot of work, cutting, welding, adding material porting, etc. not worth the time.
SDPC sells a kit to make a EGR work for their Vortec TPI intake...It just involves cutting a hole in your header. I wasnt a big fan of that idea so I just blocked it off...Its doable just buy the kit and ur all set!!
Jason
84z96L31vortec
Aug 20, 2017 12:16 AM
Tinbender59
Mar 17, 2017 10:50 AM
earlpote
Aug 28, 2015 10:42 AM
L98GTA87
Aug 11, 2015 06:55 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
