replaced balls in headlight motor..now it will close...but motor wont turn on........
Old Mar 2, 2001 | 05:05 PM
a1987formula350cu's Avatar
replaced ***** in headlight motor..now it will close...but motor wont turn on........
i replaced my shredded plastic ***** in my motor w/ some 10mm(approx .39") steel ones. It now will go down with no problem and wont keep running after its down but the motor wont even spin to lift it up when i turn the lights on....i have to manually spin it?? PLEASE HELP B/C THIS IS SERIOUSLY PISSING ME OFF...thanx
1987 Firebird Formula 350[*]Stock except...[*]Cragar Street Stars
My Car Website w/ Pics
fyrebird350@hotmail.com
AIM/AOL: FIREBERD350
<<<<---THIS CAR IS FOR SALE(only 49k)--->>>>
[This message has been edited by a1987formula350cu (edited March 02, 2001).]
Old Mar 3, 2001 | 09:14 PM
mikeage2's Avatar
HEH I DID THE SAME THING ABD I DUNNO WHY IT DID THE SAME THING.I ENDED UP PUTTING TWO NICE USED UNITS ON AND CALLING IT SPEGETTI!
86 camaro:was a v6 car,now its going to be a v-8 5.7l!!
350:cylinders bored .040 over.a little over 9:1 compression(getting a blower some day when im rich lol)line bored.deck is milled a little(was pitted)
trw forged pistons with summit stage 2 polished rods with arp bolts.
194? intake valves(not 2.02( ),pocket ported,gasket matched,and polished ports,old vette intake with new zinc 650 holley
ase certified for a few years,learned alot though
working on freakin NEONS ,cirruses,tauruses,cobras(well` at least they look nice lol)and intrepids all day makes me drink too much
good job security though
im always on the lookout for cheapv-8 t-5,s
and t-56 setups.they must be cheap.i dont care of they need rebuild,as long as they arent totally blown
Old Mar 3, 2001 | 11:37 PM
anyone have any help??
Old Mar 4, 2001 | 07:39 AM
LeeH's Avatar
Car: 89 Firebird Formula
Engine: 389
Axle/Gears: Moser 4.11
Did you check the headlight motor relay mounted on the firewall?
I remember doing this years ago, and I think we backprobed the primary wires with a voltmeter to make sure the relay was energizing when the headlamp switch was turned on and off. In my case the headlights wouldn't go on, and the relay was getting power from the switch, but it wouldn't engage. 14 year old relays do go bad after a while...
89 Firebird Formula
WS6 package,ZZ4 Crate engine
SLP 58MM TB, Edelbrock TES Headers
Random Tech 3" cat, SLP 3" stainless exhaust
9 bolt rear, Hotchiss swing arms, Lakewood panhard rod
Corvette 2/4 servo, kevlar band, full poly rear.
Centerline 16x8 rims, B.F Goodrich drag radials
Ghettobird52
Jul 5, 2024 11:18 PM
OLDYELLR
Car Audio
Sep 30, 2015 07:10 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
NBrehm
Aug 5, 2015 07:57 PM
