hydraulic, mechanical, or roller?
Old Apr 6, 2004 | 07:41 AM
screamingz28's Avatar
Car: 85 Z28
Engine: 305 LB9 TPI
Transmission: TH-700R4
I was wondering exactly what type of stock cam was put into the 85 camaro's with the 305 tpi? I am hoping that it is not the mechanical since you will have to measure the valve lash when adjusting the lash. I have someone that is going to help me adjust the lash i just need to know. That way if it is roller or hydraulic I can do it with the engine running.
Old Apr 6, 2004 | 08:06 AM
ede's Avatar
ede
hydrolic flat cam, not a roller and not a solid
Old Apr 6, 2004 | 09:05 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
theres 4 types.
  • hydraulic flat tappet.
  • mechanical flat tappet. (aka solid flat tappet)
  • hydraulic roller
  • mechanical roller (aka solid roller)
all stock 3rdgen motors got hydraulic cams. in 87 they swapped from hydraulic flat tappet to hydraulic roller.
Old Apr 6, 2004 | 10:46 AM
Car: 85 Z28
Engine: 305 LB9 TPI
thanks for the help! now i can get to adjusting. i'm glad it wasn't the mechanical because they are a pain.
88SS6SPEED
Nov 11, 2015 07:05 AM
Jorlain
Oct 8, 2015 01:57 AM
skinny z
Oct 5, 2015 06:23 PM
Damon
Sep 26, 2015 04:29 PM
jtwoods4
Sep 3, 2015 05:39 PM
