Can I mix different tires?
Car: 89 bird, 86.5 D21 Hardbody duringwinter
Engine: 305, VG30e
Transmission: 700r4, dunno the other one :)
I need to pass an inspection in NH and I have 3 pretty bad tires and 1 brand new tire, all are 16" on the fancy aluminum pontiac 16" rims
I also have 4 decent tires that are on 15" rims, two of them are good year regettas and look good enough to pass and two of them are snow tires (different brands though) that look like they might pass
any ideas? is tire inspection really checked? I have no money...
Car: 1996 Dodge Avenger ES Turbo
Engine: 420a
Transmission: NVT-350 (5spd)
I'm not really sure about NH, but here in VA, the tires just have to have more than 2/32's of tread. If they match or not, that's up to you. Personally, I'd get matching tires, but if you're in a bind and just need to pass inspection, you should be ok. Then again, like I said above, I'm not too familiar with NH laws/standards.
Engine: 420a
I believe he was inferring that he slap the 15" rims on the car in place of the 16's. And yes, I know that 15" tires won't fit on 16" rims. LOL DUH! :-D Sall good.
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
for inspections, yes.
but if you have a posi, and you put two diffrent size tires on it, it can wear it out. the two diffrent tires spin at diffrent speeds, so the posi thinks you're turning and it slipps.
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Car: 1986 Firebird
Engine: 2.8 V6
Only thing I've heard problems about with different tires at different corners is traction in rain or snow... when one tire's got great grip in the wet, and the others suck, you might be in for a wild ride!
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
MrPackstin
Oct 25, 2017 08:09 PM
