Is my CR too high!?!?!?
Old Apr 8, 2004 | 09:53 PM
daddy33's Avatar
Car: '85 Camaro
hey guys im looking into getting some Speed Pro. Part Number: H624P30 pistons which have a dome volume of 3.5cc
I did all the math and the Compression Ratio came around 11.35:1 (4.040 bore, 3.75 stroke, 68cc head, .055 gasket, .0001 deck height & 8 Cylinder)
I was wondering if the CR is too high even with running the highest octane pump gas. Here is a list of mods that are on the engine:
350 4 bolt block bored .040 and stroked with 3.75" crank (so a 383)
Edelbrock RPM Air Gap Intake, Edelbrock 750 CFM Carb
Lunati 108° Sep 104° Int C/L .534/.534" lift 295deg/245deg
1.6 Roller Tip Rockers
AFR 195cc Street Heads
Heddman 1 3/4 headers with 3" collector to 4" dynomax
Im sure their is some other little stuff but cant think of it.
Anyways i need to know if the CR would be ok so i can order the set of pistons. Oh yeah the car would mainly be my weekend warrior and couple times here and there to work. Thanks
Old Apr 8, 2004 | 09:57 PM
87350IROC's Avatar
Car: 87' IROC
Its close, you may have to run octane booster. It all depends on how good your tune is. Personally i would get flat tops and call it a day. What are the cam specs at .050" lift?
Old Apr 8, 2004 | 10:01 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
That strikes me as being too high.
I'd suggest their H860 (flat-top) instead.
I'd also suggest a .039" head gasket (FelPro 1014) instead of the 1044 you list.
And, it's going to be pretty tough to get somebody to machine your block to one ten-thousandth inch of deck clearance; I'd call that "zero-deck".
Old Apr 8, 2004 | 10:04 PM
onebinky's Avatar
From what I've heard, the highest you want to go with the aluminum heads is about 10.6:1, unless you run a really radical cam to bleed off some of the compression.
I have heard of guys doing this with up to 14:1 compression on 93 octane without issues, but I don't know if thats fact or fiction.
And if the valves are open that long, wouldn't that defeat the purpose of a high compression motor in the first place?
Old Apr 9, 2004 | 07:24 AM
daddy33's Avatar
Car: '85 Camaro
the cam @ .050" In/Exh is 245*.
So my best bet would be to go no higher then 10.5:1 to not run in any problems even though im sure there might still be some..
Anyways ill check into those flat top pistons that Speed Pro has
Old Apr 9, 2004 | 08:22 AM
ronterry's Avatar
Car: '94 Corvette
Oh you can run 14:1 on street gas, but your not going to ignite the a/f until it's on the down stroke – i.e. retard the timing to nothing, and kiss any performance good bye.
BTW: I like the Felpro 1010 (.039) because it uses copper instead of steel for the compression seal. A lot better on aluminum heads.
Ron
Old Apr 9, 2004 | 08:48 AM
daddy33's Avatar
Car: '85 Camaro
Ok well i did the math and im getting the Speed Pro H860 (flat-top) which when i did math came close to 10.3:1. And that was with the .039 gasket which i will going with also.
sp8ty
South East Region
Sep 24, 2018 03:55 PM
sp8ty
Exterior Parts Wanted
Oct 23, 2015 08:35 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
Zell1luk
Sep 29, 2015 10:36 AM
