Tapping Harmonic Balancer
Old Mar 5, 2001 | 09:39 AM
El Guapo's Avatar
One of the pulley attaching holes on the HB is stripped. Is it ok to tap the hole, or would that throw the whole thing out of kilter? ld hate to go buy a new HB if l can tap and continue to use the current one, however, the thought of it shredding at 4K RPM isnt all that great either.
Clayton
Old Mar 5, 2001 | 09:53 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Heli-coil it.
ICON Motorsports
Old Mar 5, 2001 | 02:57 PM
JakeJr's Avatar
Car: 1996 Vette / 1992 GSX1100F Suzuki
Engine: 1996 Corvette Coupe 388 LT1 (+.060)
Axle/Gears: 3.07
Sure, either tap it or heli-coil it.
Tapping would be a little easier if only the first few threads are stripped, as would happen if a bolt with the wrong thread was tried. As long as the bolt will hold the final torque reading.
Sometimes you'll grab the wrong bolt, like a 3/8-16 and start screwing it in only to realize it's the wrong thread after that sucka gets too tight to turn further - been there, done that. Usually only the first couple of threads are damaged.
Jake
1986 Corvette Coupe, 415 CID, Edelbrock 6073s, ZZ9
[This message has been edited by JakeJr (edited March 05, 2001).]
Old Mar 5, 2001 | 10:33 PM
Vader's Avatar
El Guapo,
Oh Crappo! I jate it quando that jappens!
Check this link for your repair needs:
McMaster Threaded Inserts
Browse their listing for similar products, too.
Later,
Vader
"I'm'a do Things My Way - It's My way or the Highway."
Adobe Acrobat Reader
Fred SS
Oct 12, 2015 11:27 AM
monte87cortez
Sep 26, 2015 08:10 PM
steimel94
Sep 20, 2015 12:46 PM
Magman
Sep 13, 2015 12:14 AM
dimented24x7
Sep 6, 2015 03:51 PM
