Timing for LG4?
Old Apr 9, 2004 | 09:06 AM
H.O.bluebird's Avatar
Car: 1987 T/A
Engine: 305H.O.
Timing for LG4?
I want to check the timing on my 86 LG4 Trans Am but everything I read to get the info says I must go off the emision decal under the hood. Unfortunatly that decale is long gone so I need some help.
1. what is the base timing for this engine?
2. I cant find the standard tan with black wire to disconect the computers control of timing,Is there one to disconect on this engine?Is it a diffrent color?
3. Can anyone take a pic of an LG4 emmision decale so I can see all the info on it?
Thanks guys
Old Apr 9, 2004 | 09:42 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
IIRC the factory spec base timing was 6° BTDC.
It doesn't use the tan wire like the FI motors do. Instead, you disconnect the 4-pin plug that comes from the back of the distributor, usually hangs down behind the driver's side head.
I would set the timing as described, and adjust it from there, until you find where the engine runs the best.
Old Apr 9, 2004 | 10:12 AM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
not to be a dick or anything but a LG4 isnt isnt a H.O engine, thats an L69
Old Apr 9, 2004 | 10:28 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
It doesn't matter. 6* base should be fine. If he hears knock he can go to 4*.
Old Apr 9, 2004 | 06:02 PM
Marc 85Z28's Avatar
Not for the LG4... At least not the 85 cars. My underhood label shows 0 degrees base timing.
Old Apr 9, 2004 | 06:13 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I've still got the underhood stickers. It says 0 degrees.
I found that (with a functioning EGR) 6 degrees was much better when the engine was still stock (with plugged EGR passages, I'd get part-throttle pinging under load).
Now, I'm running 10 degrees base, burning 85 octane gas (that's regular here) with no pinging problems whatsoever. Even went through "fast pass" emissions testing with it that way. Part of the reason I can get by with that much advance is altitude, but 6 degrees shouldn't be a problem at sea level.
RazorN8
Jan 7, 2022 11:44 AM
bamaboy0323
Sep 3, 2015 06:07 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
Thirim
Aug 9, 2015 06:19 PM
