knock sensor?
Old Mar 6, 2001 | 10:46 AM
Ringmaster72's Avatar
Car: 1989 IROC
knock sensor?
I am putting my motor back in after rebuilding it and I am having trouble remembering where the knock sensor goes. I know it is on the passenger side, but I dont see a hole for it in the block--could the machine shop have plugged it? Also, I am not sure where all of the wires that are in the starter harness. I know the ones that go on the main post and one to the knock sensor, but where does the other one go?
Old Mar 6, 2001 | 01:06 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The sensor goes in the block coolant drain. The shop may have put a plug back in there.
You should have the positive battery cable and the large terminal wire from the harness on the large starter solenoid post, and the small terminal wire from the harness on the small solenoid post.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R. 2.93 limited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/LB9 block, ZZ3 cam and intake, WP 305 heads ported & polished, Hooker headers & y-pipe, 3" Catco cat).
57 Bel Air, my 1st car. 0.030 over 396, Weiand Action+, Edelbrock 1901 Q-Jet, Jacobs Omnipack, 1-3/4" headers, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Best 15.1 @ 5800' Bandimere. Daily driver while Camaro was being put together.
L98GTA87
Oct 19, 2015 10:43 PM
cking99
Sep 22, 2015 11:33 AM
sreZ28
Carburetors
24
Sep 21, 2015 04:54 PM
BLK87Z
Sep 18, 2015 11:29 PM
FormulasOnly
Sep 10, 2015 09:07 PM
