Engine code 51?????????????
Old Mar 5, 2001 | 07:06 PM
Blue5.71LE's Avatar
Hey guys I'm kinda stumped. I checked for codes cause my check engine light came on, and i got a code 51. Now i know it for a prom or ecm related problem.My question i read that after you clear the prom the car may run rough for a little bit(40 miles or so). I parked the car for the winter and have been getting ready for summer the last couple of weeks.So could the fact that it hasn't been driven cause this? or does the prom just die alll of a sudden like that?
Old Mar 5, 2001 | 08:40 PM
theformula's Avatar
I got the same code man. Are you getting any other codes with it???
I'm stumped too
91 Formula
305 TPI 5speed
1LE/G92/WS6
Paxton SN92 polished kit, SLP airfoil, ported/polished plenum, March pulleys, Crane AFPR(43psi),Crane Gold 1.6rrs,MSD coil,MSD6AL (5275rpm limit),Holley 9mm wires,Ac delco R43ts plugs,fastchip,Ford SVO 24# injectors,Bosch O2sensor,SLP 1 5/8" headers,SLP catback,shortened shifter,3:73s w/Auburn posi,170* t-stat,JET 195* fan switch, Macewen white face gauges, Autometer gauges, Zoom hi-performance clutch.
Old Mar 5, 2001 | 10:28 PM
Yam's Avatar
Yam
The only thing I can think of is that your battery isn't giving the PROM enough power or that you disconnected it when you parked for the winter. If the PROM isn't getting enough power it could be scrambling the memory (tables).
I'd say just make sure the battery is fully charged up, drive it around a little, then reset the PROM. The reason it's a little rough when you first reset it is because the PROM 'learns' what type of fuel you are using and a bunch of other stuff. Then it rewrites the fuel map.
Old Mar 6, 2001 | 01:42 AM
formula90's Avatar
Car: 1990 Formula
Engine: 5.7 liter
MEMCAL or ECM failure. The MEMCAL supplies the ECM with information concerning the exact vehicle and engine combination, including "limp home" data.
And yes, things like this do happen. if you can, swap your ecm with a known good one and see what happens. let us know
I have experience...unfortunatly,its a result of bad judgement.
click below to check out MY FORMULA PAGE!
http://www.formula350.com
or click below to email me
astralbaby11@hotmail.com
Old Mar 6, 2001 | 09:30 PM
Blue5.71LE's Avatar
hey guys thanks for the replies. I took her for a good run, and after it warmed up the light was gone, and it was running great.I reset the prom again, took it for a little run and the code was clear. Oh ya it was the only code showing at the time.
One other annoying tidbit.What causes that ratteling noise on the AC compresser??I noticed it for the first time when the car was warming up.????????
91'1LE Z28
K&N Filter (just getting started)All show no go.For now.
Spyder_TheGamer
Dec 25, 2015 05:07 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
mizz0313
Aug 12, 2015 06:45 AM
