? about changing valve guides
Old Mar 7, 2001 | 11:05 AM
chris1roc's Avatar
Is is hard? When I do should I put new springs in? I just need to use the air compressor attachment for my spark plug hole, right?
How can you tell if you are burning oil because of your valve guides or rings?
All help will be greatly appreciated
88 iroc
305 tpi
k&n, flowmaster, ADS chip
160* thermostat
home made ram air
removed smog pump
ASCD big block hood
[This message has been edited by chris1roc (edited March 07, 2001).]
Old Mar 7, 2001 | 12:19 PM
fb305svs's Avatar
Car: 1991Firebird T/A
Transmission: Modified Viper t-56
Axle/Gears: dana 44, 3.55
well, someone correct me if i am wrong, but what he is actually gonna be changingin the car is the valve SEALS right? to change the guides the heads need to be removed and have the old guids pressed out and new ones pressed in... but yes, the procedure you got is correct, pressurise the cylinder with air, to keep the valve up, yank the vlave springs, yank the seals, and then revrses with the new seals.....
Steve
to tell if your burning oil cuz of your seals, one check you can do, is run the car, get it good and hot, then let it sit till it is cold, then pull the plugs... if they are wet/oil coated, then that is a good indication... otherwise, if it is rings, the smoke would not go away after running a few minutes at the most... i know within one mile of driving my car it will burn everything off... also, try using a heavier weight oil like 10w 40, i know that makes mine smoke very little when compared to when i accidentally use 10w30.. doh!
[This message has been edited by fb305svs (edited March 07, 2001).]
deracer
Apr 11, 2016 12:04 AM
Cameeeero
Sep 18, 2015 04:00 PM
camaro71633
Sep 1, 2015 10:24 AM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
