What other free mods can I do?
Old Mar 7, 2001 | 11:18 AM
chris1roc's Avatar
I already took out the smog pump. I did the TB coolant bypass. I made a home made ram air. What else is there to do that will be very close to free that will make my car go faster?
88 iroc
LB9 305 tpi
k&n, flowmaster, ADS chip
160* thermostat
home made ram air
removed smog pump
TB bypass
ASCD big block hood
Old Mar 7, 2001 | 11:59 AM
Bort62's Avatar
Advance your Timing
60 Ranchero - Project ( Money Hole )
85 Sport Coupe LG4 - Daily Driver
Just another Hot Rod kid, or thats what they all tell me.
Livin' the Stereotype
Old Mar 7, 2001 | 01:38 PM
84TransAm's Avatar
Take some weight out of the vehicle.
Not really a mod, but it helps alot.
--Steve S--
1984 Trans Am 305 LG4, 5 speed
Daily Driver, Flowmaster 80 Series
NOW FEATURING: Holley 600 cfm & vacuum advance
[This message has been edited by 84TransAm (edited March 07, 2001).]
Old Mar 7, 2001 | 02:13 PM
BrianB's Avatar
Port the plenum, cut the screens out of your MAF (Mass Air Flow Sensor)
Old Mar 7, 2001 | 03:01 PM
rondubbs's Avatar
dont cut the screens out of your maf.
1988 GTA Trans Am 350tpi: 44k miles,3:27 BW rear, aftermarket t-tops
Hotchkis: subframe connectors & strut tower brace
Flowmaster: 3inch exhaust& dual chamber muffler
Accel: 8.8mm wires, cap&rotor, u-groove spark plugs
Edelbrock: 52mmTB, intake & runners
K&N: filtercharger
TPIS: 170* stat, afpr, mat relocation kit
March: performance crank and alternator pulleys
Hypertech: 176* fan switch
Other mods: ported plenum, gutted cat, tb coolant bypass, flux capasitor
Old Mar 7, 2001 | 04:45 PM
Dan87IROC-Z's Avatar
You can get rid of your A/C, the less pulleys you have to turn the better. Each belt talkes about 7-10 hp away, so the less you have the better. ALthough it will cost you like $20 to have your AC evacuated.
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Borg Warner 7.75" 9 Bolt Rear End
Current Mods: LT4 Hot Cam, Comp Cams 1.52:1 Roller Rocker Arms, Edelbrock TES 1 5/8" Headers, Hooker 3" Aerochamber Cat-Back System, Performance Resource Chip, Accel Ignition Coil, Cap, Rotor, 8.8mm Wires, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET (w/o LT4 cam): 14.32 @ 97.7mph
(corrected for elevation)
7.5" 10 Bolt with 3.42s soon to come!
Hotrodboba400
Dec 10, 2019 07:07 PM
Nervous2
Oct 8, 2015 10:53 PM
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
masonta
Sep 1, 2015 06:40 PM
