true that stock 4gen vortek heads???
Old Apr 13, 2004 | 07:19 PM
FOX-GTA_89's Avatar
Car: GTA WS-6 1989 fully loaded
Engine: 1995 9C1 LT1 police pak XE cam
Transmission: t-5 borg warner
is it true that aluminium heads on lt-1 95 are same as pick up iron heads vortec desing?
Old Apr 13, 2004 | 07:22 PM
Abubaca's Avatar
I don't think so.
Old Apr 13, 2004 | 08:13 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Nope. The LT1 is a totally different animal.
Old Apr 13, 2004 | 08:44 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
The L31 heads were copied from the LT1 heads on the Caprice/Roadmaster which actually flowed better than the LT1 heads on the Camaro/Firebird and 'Vette but they're cast iron.
So no.
Old Apr 15, 2004 | 01:46 PM
Damon's Avatar
The LT-1 and LT-4 heads have their own unique intake bolt pattern. It isn't the same as Vortecs and it isn't the same as earlier bolt patterns, either. It's it's own unique animal.
LT-1 aluminum heads have intake ports and chambers similar to earlier non-vortec heads.
LT-4 aluminum heads have ports and chambers that are almost identical to cast iron L-31 Vortec heads, but they still don't share the Vortec intake bolt pattern.
I beleive that with some re-machining you could make an LT-4 intake manifold bolt to cast iron vortec heads. Obviously, you could also use a Caprice intake to bolt up to them, as well, since they were designed to work together in the first place. LT-1 heads won't fit on an L-31 Vortec cylinder head, however- the ports won't line up right, even if you got the bolt pattern the same.
Remember that if you're using the LT-4 or Caprice intake on your Vortec heads you STILL have to make provisions for water ports since earlier motors don't have reverse-flow coolant systems. You have to do some drilling, tapping and plugging. Ask around with anyone who has converted an LT-1 intake for use on an earlier engine how they did this. It's not very difficult, but it has to be done if you are not running a late model reverse flow cooling system type engine.
MustangBeater20
Oct 29, 2022 09:20 PM
okfoz
Mar 9, 2017 02:35 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
gta90
Sep 15, 2015 04:00 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
