WOnt start...
Old Apr 14, 2004 | 01:41 PM
MaD_87_fOrMuLa's Avatar
Car: 87 FireBird Formula
Engine: 305 4bbl
WOnt start...
Nothing at all when I turn the key...Everything lights up but the motor doesnt make a sound...Starter?
Old Apr 14, 2004 | 02:21 PM
ede's Avatar
ede
check for power to the starter
Old Apr 14, 2004 | 02:41 PM
IROCZ28dan's Avatar
Car: 1987 IROC-Z
Get someone to crank the key while you tap the starter solenoid with a hammer. If she starts, replace your starter.
Old Apr 15, 2004 | 02:32 AM
SchwarzCamaroRS's Avatar
if you do what ede said and youve got power, thats the starter... just did 3 in mine last week.. the stock starter died, so got a new one, that one got shorted out in the solenoid cuz my dumb@$$ friend broke the cap and the 3rd one worked perfectly.. they are relatively easy to do.. about 1 hr under ur car if u take a long time.. but check for rebuilt starters if you get a new one, i have seen a trend where they make the solenoid caps out of plastic... if yours looks plastic, then put a hoseclamp around it before tightening your electrics down, thats a little trick i devised when my friend destroyed my old solenoid cap... but, if you dont have power @ the starter, check the battery connections, follow all the wires as far as you can and look for shorts...
Old Apr 15, 2004 | 02:34 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Shorts as in the fusible links. Those love to go out at the mose inconvenient times......
Old Apr 15, 2004 | 02:56 AM
yes they do... that, and old wiring... sometimes if the wires get hot, the coating dissapears and exposed wires always seem to find some sort of grounding point in an engine compartment... not much of a problem for newer cars with all aluminum and plastic engines.. poor us with quality craftsmanship, we get the electrical problems
Old Apr 15, 2004 | 10:38 AM
Engine: 305 4bbl
Like when yours ouyt of cigerettes and late for work?
That kind of thing???
Im on it today...Ill let u guys know...
Old Apr 15, 2004 | 12:01 PM
Engine: 305 4bbl
Tapped it and it starts fine now...Should I get a new one, or let it go???
WIll I be ok, cause im kinda low on $$$ right now...
Old Apr 15, 2004 | 12:30 PM
try to find a place that will sell remanufactured ones.. they work fine when youre low on cash.. and they arent that hard to change out... i got mine for 60 + core... but deffinately heat shield it if you dont want it to die again... you should be ok if you want to just keep hitting it everytime it dies though, but do replace it as soon as you have the money
Old Apr 15, 2004 | 01:26 PM
copperhead110's Avatar
You could let it go, but you'll need to tap it more and more often and then one day you'lll be stuck.
The brushes are worn in the starter. A little tap moves things just enuf so it will crank.
Old Apr 15, 2004 | 04:14 PM
Engine: 305 4bbl
THanks guys...had to start it a couple times today so far and no problems yet...I plan on gettign on when i have the $$$...Just kinda low right now..
thekurlyone
Sep 30, 2015 12:54 PM
nathan2003
Aug 4, 2004 12:14 AM
shapeshifter
Sep 20, 2003 12:09 AM
Knyghtmare
Jun 15, 2003 09:10 PM
Drowned
Dec 8, 2001 05:58 PM
