replacing the fuel pump
Old Feb 14, 2001 | 08:39 PM
88'camaro305TBI's Avatar
Car: 88 IROC
Transmission: auto
I have just diagnosed my fuel pump to be bad. Has anyone replaced it without taking out the tank? I mean, cutting into the trunk in order to reach the fuel pump that way? If so, where did you cut it and how big? I have a welded hooker cat back on my car plus the car is parked on the street, so it would be a big pita to do this from underneath. thanks for any help
88 305TBI
Mods:Hooker Aerochamber 3" exhaust, gutted kitty, March pullies, no smog, 180 thermo,
14x4 K&N, 3.42 gears,
Eibach springs with KYB's all around,
Harwood cowl hood, Z-28 wing, fresh paint(black)
120,000 miles, 5spd, T-tops
Run a best of 16.7 @85mph before gears
92 RS, 305TBI, auto, 3.08 gears, 180 thermo, glasspack (no muffler)
Old Feb 14, 2001 | 10:02 PM
JoelOl75's Avatar
Car: 88 Firebird WS6
Sorry, gotta drop the tank.
Old Feb 15, 2001 | 12:36 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Yup, drop it down. Where is your cat-back welded? It's not welded at the cat, is it? If so, ouch. Hopefully it's not- when you drop the rear axle down to the ground, you can pull the whole cat-back out from under the car. I actually just left my cat-back under the car, on the ground, and worked around it.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Feb 15, 2001 | 01:13 PM
Justin 87 GTA's Avatar
Car: 1987 GTA
Engine: 645hp/656 ft lb Blown 383
Transmission: 700-R4 3,000 stall
Axle/Gears: 3.55 moser 12-bolt
No, you can cut a hole. I've heard of a few poeple doing this. it's not hard, i just can't tell you how to do it. it's much easier and quicker hr. you need to pull up the carpet and go throught the top of the tank, right behind the rear seats.
SUPERCHARGED 87 GTA: Blk/Gld w/Superam, 355cid Trickflows, forged pistons 9.5:1. Auto 2,600 stall, 3.45 9 bolt disc, Best time & mph (Naturally Aspirated): 13.567 @ 101.900 w/ a poor 60ft. Best mph: 104.3 *This car is 100% NYS emissions legal, w/ all emissions controls!* "If you want to have a fast car, hang out w/ those who do!"
http:// www.community.webtv.net/munks87/JustinsGTApage.com
VORTECH S-TRIM, INSTALLATION IN PROGRESS: 10 & 15 LB> PULLEYS, CUSTOM HKS RACE BYPASS, CUSTOM DUCTING W/ COLD AIR, SWAPPING TO SERPENTINE, & MANY EXTRAS! BEST TIME: 11'S I GUESS. WE'LL SEE IN SPRING!
Old Feb 15, 2001 | 04:39 PM
Car: 88 IROC
Transmission: auto
Yeah, i guess either way would work, but it would be nice if I could make that trap door behind my seats so i can replace the fuel pump more easily not just now, but later in case i'll need a high flow fuel pump.
Old Feb 16, 2001 | 11:33 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
What happens if he cuts into the tank by accident, though?
Old Mar 7, 2001 | 09:15 PM
Dsaint's Avatar
I cut a hole myself in the trunk with a dremel, just make sure you empty the tank. I made sure to make it easy to get to in the future.
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
justin57
Aug 20, 2015 07:05 PM
drewdock87
South Central
Aug 18, 2015 09:02 PM
92camaroJoe
Aug 13, 2015 06:07 AM
