Anyone use the Hot cam in a 305?
Old Mar 7, 2001 | 07:11 PM
R.O.B.'s Avatar
I was just wandering how well the LT4 Hot Cam would work in a 305. I have a roller 305 block in my TA, and was thinking of adding a chip, Vette heads, SLP runners, and an Edelbrock baseplate to what I've already done. Do you think this cam would work. My Dyno2000 estimates 330hp.
Rob
'86 TA 305 TPI
Gutted MAF, Ported Plenum
TB Bypass, Home made Cold Air Intake,
Edelbrock T.E.S.
[This message has been edited by R.O.B. (edited March 07, 2001).]
Old Mar 7, 2001 | 09:09 PM
Dan87IROC-Z's Avatar
The HOT Cam is too big for most 350s, mine included, I wouldn't dream of putting it in a 305. I would look into the smaller SLP cam sold in Summit, my friend uses that in his 89 IROC along with cat-back, chip and 3.73s and he's running like a high 14s.
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Borg Warner 7.75" 9 Bolt Rear End
Current Mods: LT4 Hot Cam, Comp Cams 1.52:1 Roller Rocker Arms, Edelbrock TES 1 5/8" Headers, Hooker 3" Aerochamber Cat-Back System, Performance Resource Chip, Accel Ignition Coil, Cap, Rotor, 8.8mm Wires, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET (w/o LT4 cam): 14.32 @ 97.7mph
(corrected for elevation)
7.5" 10 Bolt with 3.42s soon to come!
Old Mar 7, 2001 | 09:26 PM
JP84Z430HP's Avatar
Car: 84 Z28
Engine: 355 (fastburn heads, LT4 HOT cam)
Axle/Gears: 9-bolt, 3.27
I sort of agree, to use the LT4 HOT cam in a 350 you need a pretty good package already. I think I will, seeing that it's the same thing that GM did to get 430 HP! Maybe with my .030 overbore, and Zero-Gap rings, I can get 450 HP!
Working on:
'84 Z28 LG4 305 with 200,000 original miles!
Added dual elec fans.
145 MPH IROC Speedo
Building 430 HP 350 (ZZ430)
using primarily GMPP parts.
Short block sitting on a stand.
Starting to look like the Kicker poster child!
ASE Certified Master Tech
Jake_92RS
Jan 28, 2020 10:37 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
beastin91rs
Oct 9, 2015 07:38 AM
theurge
Aug 21, 2015 12:46 PM
