OK, I think did it wrong and I'm now doing this backwards, but I need help...
Old Mar 7, 2001 | 07:39 PM
crazeinc's Avatar
Alright, this pertains to the master disconnect switch. The way it is now is a cable running from the positive starter cable to the switch and then a cable from the switch to the positive battery.
This is all fine and dandy for when the car is off and I'm working on the motor and won't shock myself in the process, but I also want this same switch to cut the motor off.
Stephen drew up a diagram, but that's not working for me. The only way I can get the switch to cut off the power to the motor is to unplug the alternator power lead and then since the car's running off the battery, it shuts off when I turn off the switch.
Is there a way to disconnect the lead to the alt as well as the lead to the starter without shorting the circuit, making the disconnect worthless.
I hope this is making sense. Basically it seems to me that I'm trying to make a switch do 2 different things and I'm going to need a switch to cutoff the starter and a switch to cutoff the alternator. Can anyone prove me wrong??
Thanks.
1982 Camaro Z28
should be running 11's this spring...we'll see
Check the website for progress http://members.fbody.com/Pro82Z/
Old Mar 7, 2001 | 10:50 PM
MeanYellowZ's Avatar
PJ, you should just have to interrupt the large red wire going from the alt, as in cut it in the middle and the middle being your master disconnect. I e mailed you a pic of what I think.
Randy
Currently own: 2001 Xtreme, 85 IROC, 87 S10
pics of my old 86Z:
Camaro1 Camaro2 Engine
More at: My Directory
Email: MeanYellowZ@hotmail.com Aol/IM: RCY1980
Old Mar 7, 2001 | 11:05 PM
actually i dont know what my diagram is...im not sure....go to http://fp.geocities.com/meanyellowz and scroll all the way to the bottom and hit wirediagram.bmp...
the more i stare at this i think it would work, because when the switch was on, it would allow power through it from the alt to keep the car running and when off it would cut off the wire going to the starter and end all power/ charge from the battery.
Anyone else feel free to look at my diagram
Fanatic1074
Oct 3, 2022 05:57 AM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
sheachopper
Jul 31, 2019 11:27 AM
AmpleUnicorn88
South West Region
Dec 11, 2015 11:53 PM
1HotZ28&SS
Sep 28, 2015 08:58 PM
