Accel DFI 7.0 - When will it be out?
Old Feb 22, 2001 | 05:43 AM
Bill Kirsch's Avatar
Anyone hear anything about the DFI 7.0 release date? I'm hearing the end of March. Can anyone confirm/deny this?
Bill
Old Mar 7, 2001 | 08:40 PM
Joseph Andres's Avatar
Car: 1991 GTA Convertible
The DFI set up is already out. I have seen it installed in a few third gens. It frees up to 70-80 HP in a stock TPI through infinite tuning. http://www.Cartek.net has been installing it for a while now. They charge about $1800 for the complete install and complete tuning on the Dyno Jet. It takes them about 2 days to finish the job.
1988 GTA 5.7L TPI Auto
355 ci. block, SLP Cold Air Intake w/ K&N, fully modified MAF Sensor, TPIS 52mm Throttle Body w/Air Foil, Fully Ported and Polished Plenum, Nikel-plated Ported SLP Siamesed Runners, Ported TPIS Big Mouth Intake Manifold, stock heads w/ 1.52 Comp Cams Self-aligning Roller Rockers, TPIS ZZ-9 Roller Camshaft, TPIS Valve Springs, Cloyes True Double Roller Timing Chain, TPIS Adjustable Fuel Pressure Regulator, Balanced Bosch 22 lb/hr Fuel Injectors, MSD 6AL, Taylor 10mm Wires, Bosch Platinum +4 Spark Plugs, MSD Blaster Coil, March Underdrive Pulleys, 6 3/4" Vibratech Streetdamper, TPIS Level 4 PROM, 160 T-stat, Low Temp. Fan Switch, Stock Distributor w/ Bronze Gear, SLP 1 3/4" Headers, Random Technologies High Flow Cat., Adjustable Borla Cat Back Exhaust, Flow Tech Pre-Cat 3" Exhaust Cut Off, Level 10 PTS-3 700R4 Trans, B&M Holeshot 2400 Stall Converter, B&M Trans Cooler, TCI Aluminum Finned Trans Pan, Torque Converter Lock Up Switch, 3" Balanced Aluminum Driveshaft, 3.73 Richmond Gears, Auburn Pro-Series Differential, Aluminum Differential Cover w/ Main Cap Preloads, BF Goodrich Drag Radials 255/50 R16, Hotchkis Lower Control Arms, Hotchkis Panhard Rod, Hotchkis Tie Rod Adjuster Sleeves, Bilstein Heavy Duty Shocks and Struts, 1LE Springs, Energy Suspension Polyeurethane Bushings, Global West Tubular Subframe Connectors, Global West Steering Box Brace, HP Motorsports 3 Point Strut Tower Brace
"Why ride a stang when birds can fly?"
http://www.geocities.com/thegta
Old Mar 7, 2001 | 10:07 PM
87Z-ya's Avatar
Uh no, they havent officially released the version 7 yet. Its still in testing. If it were me I wouldnt purchase one untill they have been out and running for at least a year. I waited along time for accel to come out with it, but they have been dragging their feet. I got a speed pro instead. I would hate to be a lab rat for accel using my own money and car.
87z 383,afr 190's, comp hyd roller(242/248-.540/.562,114 sep),Ported and polished mini ram, 30lb inj, 3.42 gears, tremec 5spd, , 1,3/4" slp headers, speed pro bank to bank-wb02.
"Just remember children, no man can beat you once youv'e found the cliterous." 'chef'
Old Mar 8, 2001 | 03:22 PM
TransAm223's Avatar
What exactly is the DFI 7.0?
Fanatic1074
Oct 3, 2022 05:57 AM
AmpleUnicorn88
South West Region
Dec 11, 2015 11:53 PM
efiguy
Sep 27, 2015 01:30 PM
e3pres
Sep 9, 2015 01:51 PM
