HELP!! Lifter stuck
Old Apr 16, 2004 | 08:23 AM
smoove2022's Avatar
HELP!! Lifter stuck
In the process of installing new crane powermax cam in my 82 t/a 305. For some reason the lifter on the exhaust side of the #6 cylinder will not come out! I've tried grasping it with a pliers and tugging as hard as I can, but the pliers keeps slipping off from the oil... I've got all the other lifters out except this one... Is there some other way to get it out?
Old Apr 16, 2004 | 08:40 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
It's probably mushroomed on the bottom. That one probably was the one that was ticking no matter how you adjusted the valves.
Pull it up as far as you can get it. Remove the cam. Put something underneath it, your hand if it will fit, to catch it; and knock it out downwards, into the cam bore. Don't let it fall into the engine, or bad things might happen.
tmellott89
Oct 14, 2015 02:06 PM
skinny z
Oct 5, 2015 06:23 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
ctoledo0834
Sep 18, 2015 04:16 PM
dimented24x7
Sep 6, 2015 03:51 PM
