Putting Distributor Back In -- Got a ?
Car: Mullitt mobile :)
Engine: it's stock LOL
Transmission: 700rJunk
Axle/Gears: 2 much 4 street not enough for strip
Pulled the distributor to get at a plug in the block for the alternate oil pressure sending unit hole. Go to put the distributor back in and the only way it will go back in is with the rotor one terminal off of the origional setting (marked a spot on the firewall and another on the plenum to line it up).
Here's the ? Can I just move the spark plug wire boots over one terminal ie: new 1 to old 8, new 8 to old 4, etc.
Thanks for the help,
Sparks a flyin'
Sparks a flyin'
Transmission: 4L80E/4L80E
If you marked it while the distributor was fully seated, it will appear to be one back as it is pulled out/put back in because of the gear at the bottom.
You probably didn't notice it turning backwards as you pulled it out, but it did. Turn it back beyond your mark on the firewall, and slip it back in. If it doesn't go down all the way, it's just not quite lined up with the oil pump drive (the "slot" to which CBernard refers).
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R. 2.93 limited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/LB9 block, ZZ3 cam and intake, TBD heads ported & polished, Hooker headers & y-pipe, 3" Catco cat).
57 Bel Air, my 1st car. 0.030 over 396, Weiand Action+, Edelbrock 1901 Q-Jet, Jacobs Omnipack, 1-3/4" headers, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Best 15.1 @ 5800' Bandimere. Daily driver while Camaro was being put together.
ok as cberbnarn explned but with this twist,.. bring the engine up to top dead center 0 on the compression stroke but dont crank it!!!!! then as he said do the screwdriver thing and see if you can get it back to the right terminal!!!just keep moving the oil pump shaft untill the dis. drops back in right!!! thats the correct way to do it !!!
89 firebird formula
356 10.5:1compression
comp cams xe262 cam
performer rpm intake
#1405 edlebrock 600
sportsman 2 heads 64cc 2.02/1.60 valves 200cc intake runner
msd 6al
h.e.i. proform 50,000 volt vac. advance ditributor
700r-4 with 3.08 first gear and 3.23 posi 7 5/8 rear end.
b trans shift kit(will kill shifts...suck dong!!)
shorty heddman hedders with custom 3" pipe y-pipe back(no damn cat!) with 40 series flowmaster!
future mods: 406 roller REALLY REALLY REALLY RADICAL!!!!!
89 firebird formula
comp cams xe262 cam
#1405 edlebrock 600
msd 6al
1992 Trans Am
May 10, 2023 07:19 PM
86IROC112
Aug 17, 2015 02:00 PM
