IAC Adjustment Screw Pic Needed!
Old Apr 16, 2004 | 10:03 PM
Annihilator's Avatar
Car: Caprice
Engine: 5.0 305 LO3
Transmission: 2004-R
If someone has a pic of the IAC adjustment screw on a TBI, please post up a pic. Thanks.
Old Apr 16, 2004 | 10:21 PM
Vader's Avatar
I'm not sure where everyone is getting their misinformation, but the IAC is NOT adjustable. It is under complete control of the ECM. The only things you can adjust that are related to it are the throttle minimum air stop screw and throttle position sensor voltage.
Old Apr 16, 2004 | 10:26 PM
Vader's Avatar
This might help a little:
You'll want to fully warm the engine, disable the IAC in the fully closed position, disable the EST (electronic spark timing), set the idle stop screw to the minimum RPM specification, then set the TPS voltage. Reconnect everything, then clear the error codes you may have generated by bypassing the EST.
IIRC, the RPM specification is 400-450 RPM in DRIVE with an automatic, 500-550 RPM in neutral with a manual.
Old Apr 17, 2004 | 01:00 AM
Car: Caprice
Engine: 5.0 305 LO3
Right, i like to say it for short :P Thanks for the info.
specialized
Jun 18, 2022 09:26 AM
IROCZ1989
Jan 24, 2016 03:55 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
blacksunshine'91
Interior Parts Wanted
Aug 10, 2015 12:04 AM
GEmrsn
Aug 8, 2015 03:15 PM
