msd 6al part2!! help asap!!!please????
Old Mar 8, 2001 | 12:41 PM
burnoutrpm's Avatar
ok i get the idea from you guys to put the msd box behind the strut towers on either side of the car but..... how and what do you mount it to???? what do i use to hold it??? how does it set there without vibrating to death???? msd tech or anyone HELLLP!!!!!!! im trying to get the car running again after the mods in my signature were applied to the engine and this is about the last thing~!
89 firebird formula
356 10.5:1compression
comp cams xe262 cam
performer rpm intake
#1405 edlebrock 600
sportsman 2 heads 64cc 2.02/1.60 valves 200cc intake runner
msd 6al
h.e.i. proform 50,000 volt vac. advance ditributor
700r-4 with 3.08 first gear and 3.23 posi 7 5/8 rear end.
b trans shift kit(will kill shifts...suck dong!!)
shorty heddman hedders with custom 3" pipe y-pipe back(no damn cat!) with 40 series flowmaster!
future mods: 406 roller REALLY REALLY REALLY RADICAL!!!!!
Old Mar 8, 2001 | 12:45 PM
mtx28's Avatar
since i sold my third gen a little over a year ago, i've forgotten what under the hood looks like. i recently mounted one on my 74 camaro on the firewall... is there anyroom there? just FYI, they are built to be vibrated around---so it most likely wont be a problem, if you want to, get some small rubber hose, like fuel line, and cut 4 1/2 cm sections off of it to put between the box and what you mount it to(screw the screws through these)
Old Mar 8, 2001 | 12:51 PM
88 427 Camaro's Avatar
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
Either drill mounting holes or fabricate a bracket. The msd comes with rubber isolators. If you don't use them, it will probably not last near as long.
Miles
88 427 Camaro
12.18 @ 113mph 1.75 60ft
Currently installing 3.73's into my 9 bolt (YES,it is a 9 bolt & YES they are 3.73's, not 3.70. 4.11's to follow soon )
www.koolmeister.com
Old Mar 9, 2001 | 08:43 AM
ede's Avatar
ede
i have mine mounted to the dash in side the car. i mounted one once where the battery sits, after the battery was moved to the rear. there is a tray one each side for a battery, would it fit there?
ICON Motorsports
1st & 3rd
Old Mar 9, 2001 | 09:08 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I used the rubber isolators with my MSD 6AL. Two of them were screwed directly to the car. The other two went to a bracket I made out of 1/16" steel; and the bracket went to the frame of the with regular self-cutting bolts.
I remember someone gave me the idea of laying a sheet of aluminum across the wiring behind the strut tower, bolting the aluminum to the car, and bolting the MSD to the aluminum. Then I found my spot (pass. strut tower, where coolant bottle was, I replaced the coolant bottle with a smaller version and put it elsewhere), and didn't use the idea.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Fanatic1074
Oct 3, 2022 05:57 AM
Hotrodboba400
Dec 10, 2019 07:07 PM
RedLeader289
May 28, 2019 01:47 PM
meeklay812
Oct 1, 2015 03:46 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
