I still have that annoying buzz...w/in...
Old Mar 7, 2001 | 06:57 PM
Stuart S's Avatar
I replaced the green relay in the convinience center, but I still have a buzzish whine and a flashing choke light occasionally. Also, the Fasten Seat Belt light glows on and off.
What gives? (86 ROC LG4)
Old Mar 8, 2001 | 09:09 AM
Justin 87 GTA's Avatar
Car: 1987 GTA
Engine: 645hp/656 ft lb Blown 383
Transmission: 700-R4 3,000 stall
Axle/Gears: 3.55 moser 12-bolt
btt
SUPERCHARGED 87 GTA: Blk/Gld w/Superam, 355cid Trickflows, forged pistons 9.5:1. Auto 2,600 stall, 3.45 9 bolt disc, Best time & mph (Naturally Aspirated): 13.567 @ 101.900 w/ a poor 60ft. Best mph: 104.3 *This car is 100% NYS emissions legal, w/ all emissions controls!* "If you want to have a fast car, hang out w/ those who do!"
http:// www.community.webtv.net/munks87/JustinsGTApage.com
VORTECH S-TRIM, INSTALLATION IN PROGRESS: 10 & 15 LB> PULLEYS, CUSTOM HKS RACE BYPASS, CUSTOM DUCTING W/ COLD AIR, SWAPPING TO SERPENTINE, & MANY EXTRAS! BEST TIME: 11'S I GUESS. WE'LL SEE IN SPRING!
Old Mar 8, 2001 | 05:38 PM
Stuart S's Avatar
Thanks for bringing this back up top, Justin...
ANYONE ??
Old Mar 8, 2001 | 06:49 PM
Hummer's Avatar
Car: 1986 Z28
I've replaced the relay and checked everything else. I think I'll just rebuilt my alternator, that's all I can think of. At least it will keep me busy.
Take 'er easy, and if
she's easy, take 'er twice!!!
Old Mar 8, 2001 | 07:33 PM
Stuart S's Avatar
I really don't think it has anything to do with my alternator - it seems to be charging normally.
Also, my Fasten Seatbelt light comes on for no reason, and goes back out...
Old Mar 9, 2001 | 02:40 PM
Teddy Z's Avatar
I don't know exactly what your symptoms are but here's my experience:
When I bought my '84 Z28 (LG4) I had an occasional buzz accompanied with the choke light flickering (the louder the buzz the brighter the choke light). It only happened once in a while so I wasn't too concerned about it. Then one day I'm cruising along, hit a pothole and BUZZ! It buzzed constantly with the choke light fully lit. I found a burnt fuse and all was well again... until the next day when I hit another bump and the fuse blew again. In went another fuse which blew immediately. I then concluded something somewhere is shorting out. I traced the wire (brown I think) from that fuse all the way up to the instrument cluster. There, in the bundle of wires that supply the instruments was a wire with burn marks and cut sheilding scraped off from rubbing against a metal bracket (which is grounded of course) for the last 16 years. Taped it up, fuse hasn't blown since and I haven't had the intermittent buzz either. I think the intermittent buzz might have been caused by slight shorting of the wire which wasn't enough to blow the fuse.
As far as you safety belt light... mine did it too until I pulled the bulb!
Happy Troubleshooting!
Teddy Z '84Z
Old Mar 9, 2001 | 04:11 PM
Stuart S's Avatar
Thanks Teddy - I am going to check it out as soon as the rain stops :grin:
I'll keep you updated...
Stuart S
1987 Trans Am LB9/WS6
1986 Camaro IROC-Z
OEM Posterchild of the soon to be Infamous Long Island Crew
GTAman
Jul 3, 2024 07:29 PM
Street Lethal
Apr 30, 2019 12:14 PM
PATRIOTIC1911
Sep 1, 2015 07:26 PM
Out-Cast
Aug 22, 2015 07:49 PM
Damon
Carburetors
Aug 9, 2001 04:41 AM
