Question about PCV and breathers (Ede?)
Old Apr 18, 2004 | 06:35 AM
Cruz'N Bruz'R's Avatar
Car: 87 Iroc Z
Engine: 383ci.
Transmission: WC-T5
I got a nice set of Pro Action valve covers with no holes for eith PCV or breather, I know I need a PCV so I made a hole and will run the PCV with a 3/8 line feeding it. Do I have to cut a hole in the other cover for a breather? Do I have to run a breather if I run the PCV?
Dave
Old Apr 18, 2004 | 06:50 AM
ede's Avatar
ede
you don't need PVC and a breather. all else being eqaul i'd run a PVC and not a breather. you might have to use a breather so you have a fill point for oil.
Old Apr 18, 2004 | 06:59 AM
Car: 87 Iroc Z
Engine: 383ci.
Transmission: WC-T5
That sounds great. I've been running the PCV in the past to the vaccum reference linked at the back of the carb which tee's off also to my power brake booster. Is this the correct spot?
I never had a problem in the past, but I read somewhere it has to get filtered air, they said nothing about vaccum. The aircleaner I'm running has no provisions for pcv hose.
Thanks again
Dave
Old Apr 18, 2004 | 12:21 PM
Car: 87 Iroc Z
Engine: 383ci.
Transmission: WC-T5
PCV vents the opne head. Do i need to run some sort of venting on the other head like a breather or a second pcv?
Old Apr 18, 2004 | 12:31 PM
ede's Avatar
ede
wouldn't hurt but not sure it'd help either. it's all venting from the same place.
Old Apr 19, 2004 | 05:45 PM
Car: 87 Iroc Z
Engine: 383ci.
Transmission: WC-T5
I see. I guess when the pressure becomes positive inside the block it's gonna be the same on both side, considering all of the oil galley's and such.
I see circle track cars runing 2 breathers on one side and nothing on the other. I guess we'll find out.
Old Jun 3, 2004 | 03:53 PM
omcrider's Avatar
Car: 1988 GTA
Engine: 5.7L/L98
The PCV pulls out vented gases via a vacuum, the breather allows air in to circulate, you shoudl have PCV on one side and a breather on the other for proper circulation. It is possible to run without either but it isn't recommended.
Frozer!!!
Jan 19, 2024 04:55 PM
Pilotrick50
Sep 2, 2015 12:48 PM
1985chevydude
Aug 20, 2015 12:29 AM
redmaroz
Aug 16, 2015 11:40 PM
