So what's up with these performance induction systems?
Any good?
http://performance-induction.jumpautos.com/
It says 10-15 horses, and i was thinking of putting it on my 305 TBI in favor of a k&n.
Most,
You'll still need to use an air filter with a ram air system.
Later,
Vader
"I'm'a do Things My Way - It's My way or the Highway."
Adobe Acrobat Reader
Later,
Vader
it will work because the air will be a little cooler,, but
the ribbed tubing is terrible for airflow & you can do much better than that by making your own. It should also be insulated to keep radiant heat out.
To increase airflow into your throttle it usually helps to increase the distance between the throttle and the top of the airfilter housing so the air has more room to make the turn.
If you don't have your air filter housing insulated from underhood heat then the cold air induction will not be as effective as it could be.
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
