pistons
Old Apr 18, 2004 | 09:08 PM
mmcdjs's Avatar
Car: 1991 Pontiac Firebird
Engine: 3.1 V6
pistons
Hey guys, can anyone tell me how I can tell the difference from a cast piston and forged piston just by looking at them? I've got the part number from the inside of the skirt, but I'm not sure what it means.
thanks.
Old Apr 18, 2004 | 09:25 PM
IROCtheRoad's Avatar
Car: 84 Z28, '15 Colorado
Engine: L69
Transmission: A4
go to summitracing.com and type in the part number in their search thing, that should tell you what ya want.
But couldnt tell you the difference, sorry
Old Apr 18, 2004 | 09:34 PM
Formula305FI's Avatar
Car: 96 SS, 88 IROC
Engine: Lt1, TPI
Transmission: m6,a4
Axle/Gears: 3.90. 3.73
the tolerences are tighter. thats what i was told atleast... forged pistons are a forged aluminum with a tighter tolerence, while cast, is just a molded aluminum mold.
Old Apr 19, 2004 | 01:05 PM
pwood02's Avatar
Car: '86 Trans Am
Engine: 355
1.)Give them a tap with a wrench
2.) listen, it they ring they're forged, if they just give a thunk, they're cast.
3.)Repeat steps 1 and 2 until they loose their entertaining effect
4.)post results.
Old Apr 19, 2004 | 01:59 PM
ede's Avatar
ede
forged pistons aren't machined to any tighter spec than any other piston. forged pistons are a bit less diameter or out of round than cast. that's why forged pistons will make a little bit of noise untill they warm up and expand a little.
Old Apr 19, 2004 | 11:55 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Forged pistons are stronger than cast pistons, and can handle detonation alot better than cast or hypers. Thats why they are the prefered pistons for very high power engines, as well as forced induction (blown, N2O, turbo) engines.
Old Apr 20, 2004 | 04:26 AM
ede's Avatar
ede
if by stronger you mean tensil strength hypers are stronger however they are also more brittle.
Old Apr 20, 2004 | 07:40 PM
Air_Adam's Avatar
Yup. Forged can handle more abuse, but hypers are harder.
Old Apr 21, 2004 | 11:05 AM
XJOSHX's Avatar
Car: 1988 Iroc-Z
4.)post results.
I like that. hahaha
NZKnight
Oct 15, 2015 02:47 PM
LT1Formula
Oct 8, 2015 08:34 PM
skinny z
Oct 5, 2015 06:23 PM
hartsmike
Oct 2, 2015 07:11 AM
Dragonsys
Sep 25, 2015 03:51 PM
