help with oil pressure....check pics
Old Apr 18, 2004 | 09:22 PM
ibwats's Avatar
Car: 1989 RS
Engine: 305 LO3
Transmission: auto
i need advice....my oil pressure at 2800 rpm is 25 psi and is verified by mechanical gauge and at idel it is at the first line after o psi....is my 305 on its last leg???? seems to run ok though....should i replace engine .it has 180k miles on it thanks for the inpute
Old Apr 18, 2004 | 11:10 PM
88Camaro350's Avatar
Car: 2002 Formula Firebird
Transmission: 4l60e
If your gauge is reading 0 PSI at any rpm the main bearings are probably toast. If it was me I'd probably a) change the main bearings or b) drive it till it dies and then replace it with a 350...
Oh wait I did do B. lol
Old Apr 19, 2004 | 01:04 AM
Morley's Avatar
Check the pickup screen on the oil pump before you replace the bearings, it may have become partially/mostly blocked by crap.
Hotrodboba400
Dec 10, 2019 07:07 PM
my86bird
Oct 23, 2015 12:20 PM
Gunsbee
Sep 7, 2015 07:10 PM
355tpipickup
Sep 4, 2015 05:32 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
