Getting her off all fours?
Old Apr 19, 2004 | 06:39 PM
87rediroc's Avatar
Car: 87 Iroc (summer only)
Engine: 5.0 TPI
Transmission: 5 speed
Hey all, I need to pull all 4 tires off my car. I'll be putting her up on jack stands, but never jacked all 4 corners at once. Any tips? Any funky noises/creaking that might occur? The car has SFCs...if that makes a difference with your tips. I have jacked the rear and the front end, just not all 4 at the same time. Thanks a bunch!
Old Apr 19, 2004 | 06:48 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: Getting her off all fours?
You can get the car off of all fours with ease. Just place your jack under the rear pumkin and lift the two rears. The put the jack under the front k member to get the front two off the ground.
Old Apr 19, 2004 | 07:14 PM
87rediroc's Avatar
Engine: 5.0 TPI
Re: Re: Getting her off all fours?
Thanks, that's what I was thinking. Guess I just needed some reinforcement from the board...
Old Apr 19, 2004 | 11:18 PM
PyRo9862's Avatar
Car: 91RS
Engine: 305tbi
Why jack the rear first? Wouldn't it be better to do the front first to reduce the chance of it rolling, or is there a reason to do the rear first.
Old Apr 20, 2004 | 06:39 AM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
thats another reason the floor jack has wheels on it ...so it can move with the car!!!..Blocking the wheels helps too.
Old Apr 20, 2004 | 06:57 AM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
It doesn't matter which way you do it. I usualy do the rear first if the car is not lowered. That way I am sure to get the jeck under the front nose without it hitting the GFX. On my car the front end is pretty low so I jack that up first. It doesn't really matter.
Old Apr 20, 2004 | 01:11 PM
87rediroc's Avatar
Engine: 5.0 TPI
Yep, I'll have to jack the front first. A jack will not slide under the front if rear is jacked.
dbrochard
Exterior Parts for Sale
Oct 10, 2015 01:02 PM
matt's 91rs/tt
LSX and LTX Parts
Oct 8, 2015 06:11 AM
usafirebird
Oct 1, 2015 01:57 PM
roysatikas
Sep 22, 2015 08:15 PM
usafirebird
Sep 21, 2015 01:23 PM
