Assembly lube and Smoke?
Old Apr 21, 2004 | 08:53 PM
BAD91CamaroRS's Avatar
Car: 91 Camaro RS 383
Engine: carbed 383
Axle/Gears: 3.42 posi
I just got my RS back together .. it has a 350 bored .060 over .. I used a white assembly lube for engines for the pistons. I had the heads done and everything is new. The engine has a blue smok out the exhaust sometimes. Usually at low RPMS. I only have about 40 miles on the engine. I'm 16 so i'm new to engine building. Thanks
Old Apr 21, 2004 | 08:59 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Transmission: So close to being a manual I can taste it
Sometimes a new engine may burn a bit of oil until the rings seat completely. Have you followed any procedure or advice for proper engine break in??
Old Apr 22, 2004 | 04:28 AM
ede's Avatar
ede
new engines tend to smoke so that's not unusual. you should of used 30w oil on the pistons and rings not assembly lube.
Old Apr 22, 2004 | 07:17 AM
Engine: carbed 383
yeah i have to vary my speeds for the first 1000 miles and not jump on it. I was told to use an assembly lube because the engine would be sitting for a month before it went in the car. I figured the smoke was normal. It just that i spent a lot of money on it and want to be positive i didn't mess anything up. By the way I'm 16 and built the WHOLE motor with little help from my dad. It has been a great experience. Now we have to work on the 55 chevy
FormulasOnly
Jul 23, 2018 08:47 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
gord327
Oct 3, 2015 01:25 PM
Badass355ciz28
Sep 28, 2015 08:31 PM
Dragonsys
Sep 25, 2015 03:51 PM
