Can I put a remote start on a carburated car?
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
Originally posted by Vader
You'll need one with a throttle kicker. Remote starts were available long before electronic fuel injection was made. The world didn't start in the eighties, after all.
Car: 1989 C4
Axle/Gears: 307
Re: Can I put a remote start on a carburated car?
Originally posted by Camaro_86
How can i get a remote start to work with my car?
If you still have a q-jet you can use the ac idle compensator solenoid. I use to have one hooked up and it worked ok but I dident use it very often.
Car: 1986 Pontiac Firebird
Engine: 305 LG4
Transmission: T-5 NWC
I prefer to go out, freezing cold or not. I just like the feeling of sitting in the seat, pushing in the clutch, pumping the gas, and turning the key. I just love that feeling. Yes, I am obseesed with my car.
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
The biggest concern would be that your car has to start the same way under all conditions (hot start, cold start, -35° +110° ) such as half a pump of the pedal, then crank for 3 seconds and be able to run unattended (no pumping of the throttle to keep it alive when cold). It would be easy to flood a warm engine, or starve a cold one.
Car: 1989 C4
Axle/Gears: 307
how would i go about using the ac idle compensator solenoid?
