LA Billet Crankshaft
Old Apr 23, 2004 | 06:42 PM
KillerRS's Avatar
I got a free brand new LA Billet Crankshaft and i need some info. At first the guy that gave it to me said it was a 327 and now he says it a 350, whats the best way to tell. It sucks i just got a Speed Demon 650 DP, so if its a 350 i will need to get a 750. My combo thus far is in the sig.
Old Apr 23, 2004 | 07:30 PM
Rembrandt's Avatar
A standard 350 crank stroke is 3.48 inches. That means the radius from the main bearing axis to the rod journal axis should be 1.74 inches.
If it's shorter than that, it's not a 350. A 327 crank should be a 3.250 stroke.
Old Apr 23, 2004 | 08:06 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
THe best way is to look up the casting number. mortec
Old Apr 23, 2004 | 09:57 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
billet would leave me to believe that this isnt a stock crank, casting number is probably not on there... measure the stroke.. that will tell you.. or if you can find a part number check your summit catalog.
Hotrodboba400
Dec 10, 2019 07:07 PM
db057
Apr 28, 2019 07:45 AM
Stangski09
Nov 14, 2015 01:27 PM
school boy
Oct 22, 2015 11:47 AM
3GZJerry
LSX and LTX Parts
Oct 14, 2015 05:17 PM
